Etched Paint from Dealer
Picked up my car from a service appointment (2 weeks with the dealer for a obvious door rattle - long story short the rattle is still present and confirmed by the service manager despite the service receptionist telling me "they got it!"). Anyway, when I went to pick up the car the hood was covered in bird ****. After washing the crap off, turns out my ceramic coating was etched. Obviously I'm dealing with my dealership to resolve this issue, but is this the kind of service I should be expecting from Porsche? How would you all aim to resolve this issue? This is my first Porsche, but I've had Ford dealerships treat me better.
997usa (01-22-2021)
Opticoat pro plus. That is the good stuff. And I've taken several cars to my installer over the years, so I trust them. This is due to bird **** sitting on my car for likely days.
I took mine in to replace driver side FAL, found a surface level smudge on the rear fender...not even where they had to work.
Luckily it just required some minimal buffing, but...the fact that they were careless and didn’t even notice (and the advisor told me he did a once over).
997usa (01-23-2021)
So to clarify it was the xpel that was etched, not the paint?
I'd go up the chain of command and start a conversation or email with the dealership GM.
ldamelio (01-23-2021)
Premium Sponsor
There’s a lot of “hype” and false promises in our industry, and unfortunately for OP, he’s getting first-hand experience of the limitations of ppf and ceramic coating
To clarify, ceramic coating will exhibit different characteristics when applied to paint vs. ppf. Paint is hardened where ppf is simply a soft and pliable plastic and is more porous
Ceramic coatings, or any other coating, is no match for bird droppings, acidic and low pH, when left on for extended periods of time. You have some comfort knowing the damage is reduced since there is a coating on your film vs no coating at all
The paint is most likely untouched and film took the brunt of it
if you can post a photo, it would help me in better diagnosing what to do
I recommend taking it to the shop that installed the ppf and did ceramic coating. They will be much better equipped to diagnose and treat the area affected
the least evasive way is to neutralize the acid that’s now embedded in the pores of ppf, use a mild paint cleanser to minimize the etching as much as possible, prep and recoat
hope this helps
hope this helps
Specializing in Porsche/Ferrari since 1995
Why choose GP...WATCH OUR DOCUMENTARY
Follow Moe HERE
GP Fastrak - Ceramic/PPF/Tint in one simple bundle - Click Here for more info
Follow Moe HERE
The following 8 users liked this post by MoeMistry:
997usa (01-23-2021),
detansinn (01-23-2021),
drgav2005 (01-23-2021),
Golfster (01-23-2021),
mdrobc1213 (01-24-2021),
and 3 others liked this post.
op, just talk to GM and tell them what you want done ."****" like this happens at dealership all the time and it is part of running the business
My suggestion is : I am taking the car to the shop that installed the PPF to assess and repair damage and I will have them send you the bill ..
end of story
most/all managers are reasonable and accommodating
end of story
