TPMS Error service necessary
My dealer said there is a TPMS service notice showing for my car but not implemented yet. Have no clue what it is about.
When I did the 10k service they said it was a three hour process, when I had tires replaced I asked them to do the recall and they said no instructions but just that there was one so I don't know.
Has my wheels ceramic coated…tire light came on, called my shop…made go to winter tires first and summer tires…while I did understand the need to do this, he obviously know what might happen…followed his instructions, and it worked….
I have a 2021 Carrera built early April. I have 600 miles on it and last night my dash lit up with a right front low tire pressure warning (>5psi drop). I pulled over to visually check and they looked fine. When going into the tire pressure monitoring screen, the fronts are both showing equal pressure (30). When manually checking the pressure it also reads the same. That’s weird. How is there a warning for 1 tire being low but when checking the TPM screen, it shows no deviation in TP??
Exactly error lights happened to me twice within last couple weeks. First time on left front low tire pressure warning (>5psi drop), Let the car sitting in the garage for a night and reset the Tire to comfort ride/full load next day, and the warning light gone. 2nd time last week on right front tire with low tire pressure warning (>5psi drop), and reset doesn't work anymore this time. TPMS totally stops working with trying all tricks suggested but no luck. A service visit has been schedule on Wednesday for checking at dealership.
