Front axle lift reliability?
Hi guys,
For those of you have had FAL spec-ed on your 911s. How has your experience been with the function? I am torn whether to spec it on my 992 tts. The system is not cheap and I believe it costs around 15k if it needs to be replaced. I want to see if any of you have had issues with it, esp. passed the warranty period. Thank you very much!
No problems with the FAL on my 2020 992 Carrera S. I got it because I had to replace the lip on my old 997 GT3 about every other year. However, even when I forget to lift the front end, the 992's lip doesn't seem to scrape in those locations where the 997 always did . I found the FAL is needed only on those exits and entrances that are unusually steep.
Any idea how many locations can be remembered via GPS to automatically engage FAL?
siberian
siberian
FAL on 2022 C2S failed after 1600 miles. I have to use it everyday on my driveway. SA called today said there is some leak in the system. I thought it worked electrically.
A quick question since you say you use it every day. Do you release FAL when you park and turn the car off?
siberian
siberian
After reading all above, I am getting worried about my coming TT with FAL… it seems FAL is something that you cannot use it everyday. Maybe it’s time to think about ordering another one without FAL to save the trouble. Had a 992 c4s and it does scratch a little on my driveway. Really a headache 🤕
OK let's get the facts here. FAL is not a problem, at least in my case and from what I gather it's reliable and the "memory" or GPS setting works absolutely flawlessly. It also states in the manual
that you should release FAL before turning the engine off as it's not meant to keep the vehicle raised with no power. This "could" cause the pump to fail under prolonged non running use, which is why I asked the question in case that's where the problem originated. Some have also raised the possibility that the car would release on its own, I don't know but if that's the case I don't understand why they would specifically note for you to release prior to shutting the engine off. Would it harm it if it's done once or twice? No, done daily...
So FAL can be used every day, I certainly do whether by -40F or 85F above, FAL works like a charm; just RTFM
siberian
![manual](https://rennlist.com/forums/graemlins/rtfm.gif)
siberian
KLOC (04-21-2022)
I have a 2022 c4s and use FAL at the entrance of my driveway. I park the car with the FAL activated and it doesn’t come back down until I leave the house and hit 40mph. Over 2000 miles and still fine for what it’s worth.
As I mentioned, the manual clearly states to release it when parked. YMMV
siberian
siberian
Master Deep (04-18-2022)
FAL is infinitely more reliable than the PCM.
The following 3 users liked this post by ipse dixit:
I thought long and hard about including FAL on my GTS as I live in an area with a lot of, what I would consider to be large speed bumps (UK). I don’t have a steep driveway or the need to use steep car parks. In 600 miles I’ve not needed it and am glad I chose against. I know if I’d had it, I’d have activated at every speed bump (I’d have felt obliged having paid for it and how annoyed would I have been scraping having paid for FAL?!). I actually feel liberated not having it. Appreciate I don’t have a TT and I’ll probably scrape my car today having typed this!
