Height PASM vs SPASM
My normal PASM car’s height is 75cm back and 72cm front. De front spoiler, so not the protection lip, is at 23 cm.
i was wondering if the SPASM height is exactly 1cm lower on all places or that there is more difference.
Back
Front
Spoiler
Back
Front
Spoiler
I'll measure mine when I get home. The ride height and wheel gap of my regular PASM C2S Cabrio is SUV like and rather silly looking - I'm curious how it measures up to yours. My front also sits higher than my rear, or so it appears visually.
This is interesting. I checked my car, also PASM (so not the lowered option) and I am sitting at 73.75cm rear and 71.5cm (see pictures).
What size wheels are you running? I have the 20/21 combo.
I also have the Michelin pilot winter tyres, but these shouldn’t make a difference as they are the exact same size as the factory tyres.
rear below
front below
rear below
front below
i also have 20/21 setup on Pirelli Zeros (NA coded). I think the difference between our cars is big! 1 cm is Spasm style difference! Crazy ...
Looks to be pretty consistent with about 2.55 cm (1") more gap at rear. Just doesn't seem that a 1 cm (0.4") additional drop with SPASM would make that much visual difference.
My C2S with PASM is 71.75 cm (28.25") front and 74.30 cm (29.25") rear--20/21 Carrera Classic wheels with 30/33 psi comfort pressures. Yes, tire inflation can make a difference.
C2S with SPASM: Front 70.5, rear 74. Facia to top of splitter, 21. 20/21” Spyder wheels with standard rubber and 32/41 psi cold.
C2S Cab PASM + 20/21 on Goodyear F1s + FAL + PDCC + RAS +18way seats (she's a heavy girl)
*measured with 1/8 tank and 35/38psi
Front = 72.1cm (74.1cm w/FAL up)
Rear = 71.9cm
Due to the weight of my build its not surprising I sit a little lower than some of you guys...and it still has SUV wheel gap! I don't have the rake front to rear as most of you have though...hmmm...
Rear = 71.9cm
Rear = 71.9cm
Rear = 71.9cm
I dunno...at this point I'm thinking that my FAL is not lowering completely and needs to be recalibrated (is that even possible?). Maybe need to bitch to my SA and have them check it out.
