Height PASM vs SPASM
I wish that was the case but nope...the rear sits lower than the front on this here 911. Here is the pic to see this baby in all her pre-runner glory!
I dunno...at this point I'm thinking that my FAL is not lowering completely and needs to be recalibrated (is that even possible?). Maybe need to bitch to my SA and have them check it out.
ground to fender distance measures higher in the presumed rear wheel picture.
i take it there's no shipping blocks that are still in the suspension up front? Also, the FAL is supposed to lift 40mm, looks like yours lifts 20mm based on your measurements. Now, I'm not sure if the FAL lift is supposed to be measured at the front spoiler lip or fender.
*edit* I think the rear ground-to-fender distance is still taller, but since the rear wheel is larger by 1", one would expect a larger difference between front/rear ground-to-fender difference to be more than less than 1cm. so yeah, the suspension does seem raised a bit in the front
maybe it's the angle of the picture, but picture #2 shows the wheel/tire diameter to be a smidge over 27.5 (corresponding to a 21" diameter rear wheel) and your picture #1 shows the wheel/tire diameter to be 26.5 (corresponding to the 20" diameter front wheel).
the 992 FAL system is quoted by Porsche to lift the vehicle 40mm as measured at the center of the front splitter to the ground (I need to test this still). I *did* measure the rise at the fender to be 0.875" when FAL is activated though. I've been discussing this my SA over the last day and he says to bring it in and they look it over. He said its possible the ride height sensor needs adjusting.
G650 (01-13-2021)
I need to measure at the front splitter tonight to compare to Porsches numbers.
40mm at the front splitter (Porsches measurement) will not be 40mm at the wheel well...that's just geometry. It would be some value less than 40mm. I just have no idea if 0.875" (22mm) at the wheel well is insufficient...but I suspect it is.
Now that we have our rulers out, i would like to ask if somebody would mind measure the height of a fully deployed rear spoiler with SPASM suspension. My normal PASM height is approximately 19 cm, measured from the light bar up:
My SA did say that the 992 moved to a new electrohydraulic FAL system that is different from the 991 (faster in operation), but they have not heard of any issues with it *yet*
I measured the lift height at the front splitter and I'm definitely not getting the 40mm that Porsche cites in the owners manual for the FAL system. I'm only getting 25mm. That 15mm difference seems to be pretty close to the additional gap I have in the front wheel compared to other PASM cars I've seen. This reinforces the hypothesis that the FAL system is not completely lowering or returning to its default position resulting in my 911 having its nose up in the air even when FAL is lowered. I explained this data in detail with my SA and dropped the car off today at Porsche San Diego. Let's see what they find. I'll probably get the 'ol "everything looks normal to us!" BS but fingers crossed.
please keep us updated.
Still curious. Anyone wants to meisure the height of their deployed SPASM rear spoiler?
I am interested to see this also. I also read that there is a difference between those cars with a sunroof (basically slightly more angle to offset aerodynamics due to the sunroof. Would also be interesting to know if this is always or just when the roof is opened or tilted)
@but did you die how did you get on with Porsche?
As expected...they said everything was fine and working as designed. They measured the FAL lift height of the front splitter and confirmed it was not yielding 40mm of travel. Their out here was the manual says "up to 40mm" so of course they said in certain circumstances it could be up to 40mm but not always. Mine consistently lifts 25-30mm. They also inspected the suspension and FAL system and took measurements of ride height and compared to other PASM cars they had on hand. They said right height is "within tolerance" and everything is nornal. The only good news was I got to drive around in a Taycan 4S for a couple days...that was fun!
AlterZgo (01-27-2021)
