992 Rear Reflector Removal
Bluehighways (01-14-2021)
#32
I received some satin black reflectors (I guess they aren’t really reflectors) from Bumper Plugs and have made several failed attempts to install.
Not going to attempt anymore after reading the unfortunate thread above. I went on Porsche’s technical literature portal to see how they prescribe replacing the reflectors and they say to remove the entire rear apron. I guess I’m going to take it to my Indy mechanic and get him to do it. I’m wondering for those that were able to do it without any issues if maybe you just happened to hit the fasteners at exactly the right point causing them to disengage. I thought this would be easier.
#33
#34
I had a very hard time. Mine would not break loose where the T shaped plugs are. I broke one side completely and left the other one alone, My replacement one doesn’t hold into its place as snug as the stock one did either. You’d never notice unless I pointed it out, but it bugs me.
I’d prefer painted but I’m not trying that again.
#35
BIGWORM (01-17-2021)
#36
Honestly this might be the best option - spray plasti-dip while the reflectors are on the car.
PhotoNerd (03-15-2023)
#37
I ended wrapping mine with 3M satin black 2080 vinyl. I’ve never wrapped anything and I think it came out well.
#38
That actually looks really good. But what a pain in the *** it sounds like to pull those reflectors off. I may try Plastidip whenever I get the TTS (if I decide to go with clear brake lights). It's a little ironic doing plastidip on cars like these but whatever. No one is the wiser and, like you said, if you f*** it up, you can always peel the stuff off. The Bumperplugs version doesn't quite match good enough based on the pics I've seen.
#39
The following 2 users liked this post by BIGWORM:
mdrobc1213 (01-19-2021),
rk-d (01-17-2021)
#40
Thank you. It was an expensive trial and error. But Ive since sold the red bar light to recoup some of that money back. And yes, the 3M satin black vinyl does match pretty good. Id have to agree with you that the bumperplugs ones do not match as well. I suggest you try the 3M vinyl. I just a 1x5' roll for like 16 bucks. I cut a piece about the size of the reflector and stuck it on at one end and slowly laid it down across the light. I used a heat gun to kill wrinkles and make it tight around the edges. All while they were on the car. The only scary part was using an exacto knife around the edge of the reflectors. But there is more than enough gap for the razor to not touch the paint or plastic.
#41
Has anybody done this on a Sport Design rear fascia and cost post a picture? With the body colour “shark fin “ against the OEM satin black of the rear fascia, I am unsure if the black or body colour reflector is actually an improvement over the red. I have used Bumperplug body colour reflectors on my TTS before and it looked great but these fins really are different.
#42
Curious if the folks who did this successfully did so in warmer temperatures? It’s freezing in Dallas right now and I’m not sure I want to try to pop the pieces off, but thinking when it warms up it might be a lot easier?
#43
Will consider doing what I did on my Touaregs. Pry them out and insert a string of red LEDs and tie them in to the brake lights. See below
siberian
siberian
#45
Yeah no joke it is cold. Pipes in my shed burst today.
