i have a 992 s in nj....mods are a custom tune and catless downpipes with bmc filters...I have a dragy and did one pull for the first time today. Is it better to do 60 to 130 pull from a roll or off the line? I got an 8.19 should traction be on or off and should it be in auto or manual mode
Do auto with traction control on sports +.
For launch it will do a 1 foot roll out, do a full pull and it will map it all out.
You can also do a 60 - 130 (if in sports plus) it will hold a lower gear, if in manual, make sure your revs are up when you launch.
PS. Make sure you iPhone battery is full, it will drain quickly with Dragy...
