992 wheel weights?
Old Oct 15, 2020 | 08:53 PM
Tompoodie's Avatar
Tompoodie
Default 992 wheel weights?
Does anyone know the weight of the 19 & 20 inch base wheels, Carrera S, vs Carrera classic wheels? In the 991, my recollection is that Carrera S wheels were lightest.
Cheers.
Old Oct 18, 2020 | 05:54 PM
Tompoodie's Avatar
Tompoodie
I guess I got my answer.
Either no one knows or no one cares.
Old Oct 18, 2020 | 08:15 PM
Kermit_the_Frog's Avatar
Kermit_the_Frog
Carerra S and Turbo should be the lightest as they arent casted.
Old Oct 18, 2020 | 08:37 PM
Dan Nagy's Avatar
Dan Nagy
Yes, sorry, but I searched around as well and haven’t found an answer. That info is well hidden! I just went with what I thought looked good.
Old Oct 19, 2020 | 01:43 AM
py0413's Avatar
py0413
I had experience carrying both 19/20 & 20/21 when doing seasonal swapping recently. The 20/21 definitely “feels” lighter than 19/20. However I didn’t weigh them on a scale.
Old Oct 19, 2020 | 08:40 AM
detansinn's Avatar
detansinn
Agreed, I haven't weighed them, but my 20/21 RS Spyder Design summer set feel lighter than the Base Carrera 19/20s that I have for winter. Difference could be in the tire, but it's large enough that the it's more likely the wheel.
Old Dec 30, 2021 | 09:22 PM
null's Avatar
null
Wondering if anyone had stumbled across any technical specs on wheel options, that show actual bare weights, since this thread was first posted.
Anyone know bare weights for each 992 wheel option (not what looks best, not with tires, but actual wheel weights)?
Figured I might as well as in case...
Old Dec 31, 2021 | 12:26 PM
manifold danger's Avatar
manifold danger
For some reason no one has taken the time to actually do this, and Porsche apparently doesn't want to publicize this info.
I went through this exact same thing when looking for wheel options on my 991.2; they'll show you every official stat you need for fitment, but weight is curiously nowhere to be found... some intrepid enthusiast is going to have to pull the tires off and put these things on a scale for us all to get what we deserve...
The Truth.
Old Dec 31, 2021 | 01:53 PM
Mr Bean's Avatar
Mr Bean
The Truth.
Just pull the wheel off and measure the combined weight of the tire and wheel. The tire weight can be easily obtained so that you can subtract it. Obviously do it on a newish car to eliminate any tire weight loss due to wear.
