Throttle House Drag and Roll Races 992 C2S vs Camaro ZL1
#46
lol yeah, someone (not me) add an overboots gage to their car and invalidate their warranty please....
I am 100% sure the 992 does not have an overboost and 100% sure that the only different with SR is gearbox and Turbo spool up, maybe transition and engine mounts. All the links above are to sites that are just guessing.
I'm not a racing driver nor an experience drag strip racer, however, I am fairly sure that how fast your gearbox keeps the engine in the power zone will affect your timings.... It's not just all about power is it. Is it?
#47
Received 2,841 Likes
#48
"First get your facts, then you can distort them at your leisure."
Mark Twain.
#49
If the car has a boost gauge, should be easy for someone to test. I would do it but my car doesn't get here for a couple weeks.
#50
Well, this is interesting....
https://www.caranddriver.com/reviews...y-the-numbers/
https://www.caranddriver.com/reviews...1-test-review/
Camaro should have won the rolling race easily....
BTW, Porsche underrated HP by about 10%... according to this article...
https://www.motortrend.com/news/2019...a-s-dyno-test/
#51
This is why a 911 always punches above its weight when it comes to stated power/torque numbers on the spec sheets.
#52
I had an M5C and that car WAS underrated. They quoted 617 HP and C&D got 617 WHP which means with an 18% loss (front engine, AWD) it's making over 700 hp.
#53
~ Abraham Lincoln
josephr25 (09-29-2020)
#55
I have a 718 GT4.
I think from a roll the M5 would do well and would likely pull since it realistically has about 175 hp more but from a dig the 992S would beat it because the M5C launch control is awful and you usually end up bogging down.
The M5C was quite a boring car to drive. Needed to add a Racechip Black GTS almost right away. And even then it just got old fast and got rid of it. Also didn’t sound all that good either.
#56
"The problem with quotes on the Internet is that it is hard to verify their authenticity." ![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
~ Abraham Lincoln
~ Abraham Lincoln
https://www.goodreads.com/quotes/704...n-distort-them
https://www.thoughtco.com/mark-twain...g-tips-1689230
#57
I have a 718 GT4.
I'm in the market for a 992 C4S and am most looking forward to the lighter weight and sportiness of the 911 compared to the M5. But the M5 was a beast bone stock.
#58
I could consistently get 10.89 with my vBox on my F90 M5C. Looks like the 992S is around 11.3 at best. It's a good difference.
Overall, the M5C is a beast and makes around 617 WHP whereas the 992S around 400 so the fast they’re so close in acceleration speaks quite well for the 992S. The 992S is certainly the faster track car if you’re going to track.
The BMWs make tons of power for sure but beyond being a straight line rocket it fails to deliver much else and the weight and size are major detractors for it - they don’t dance the way a Panamera does.
I think you’ll be happier in the 9924S. It’s probably the best all around sports car.
