PPF and aftermarket stripes/decals
I am not sure if I’ve seen this answered in the PPF threads. If so, please, Mr(s). Moderator, move it or delete it.
That said, I am curious about adding a stripe or decals after getting PPF. I was going to get the Motorsports Stripe, but decided it wasn’t totally my cuppa. And I want a Porsche side decal, but I am not totally loving the factory option. So I’m thinking about a center stripe and door/side decals after delivery.
WIth that in mind, I am also thinking of getting partial PPF. And then having the stripe(s)/decals added after. I was wondering if it would be better to get PPF on the areas where the stripes and decals will go, assuming that the partial PPF doesn’t cover all of those.
Hopefully this makes sense.
I’ve actually been considering adding door decals and ppf on my GT3RS as well, but I was planning on having the film installed over the decals. Curious if anyone has insight on whether the film should go over the decals or decals on the film?
Film should go over the decals. Otherwise your decals won't lay flat. They will have a ridge over the ppf. In addition, if you keep the car long enough to need your ppf replaced you won't be able to remove the old ppf without ruining your decals.
I would definitely wait on the ppf until after decals if you plan to add them later.
That was my assumption (decals first) but I spoke with two detail/PPF installer folks and they said decals after the PPF. They said the PPF wouldn’t go down as well over the decals. Also, you could always do full PPF and there would not be anything to worry about.
But I have never been a fan of the way ppf looks. I think it makes the car look too much like plastic and not like a glossy paint job. I also don't like all the scratches that develop in PPF and edges that come up over time. Even though PPF has improved a lot over the years, it still wears poorly, yellows, and looks a mess when it gets old. I would rather take my chances with just high quality ceramic or graphene coatings and avoid situations which cause road rash.
I know the popular opinion here is to not spec the car for the next owner, but I think your decision should at least take this into consideration.
For example if your plan is to keep the car for a long time and you don’t care about resale as much, I’d put the stripes under the PPF for longevity.
However if you change cars a lot and are planning to sell within a couple years I’d put the stripes over the PPF.
Just my $0.02. When I was in the market for a used 991.2 GT3, I was quite fussy with options and passed on even considering several cars once I learned that the stripes were under the PPF. I personally don’t like stripes and the though of having to pay someone to remove the entire PPF, then the stripes, then re-PPF turned me off of those cars. Had the stripes been over the PPF that I could simply peel them off it would have been a selling feature because the PPF would be an added value for me.
Hope this helps.
Hope this helps.
![](https://cimg1.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/img_9495_5ae4f5234bf9b2a73df4802830432091bf1a5836.jpg)
Hope this helps.
Hope this helps.
