is the dynamic engine mount replacement a recall? sorry if I missed this somewhere.
It is on mine . May well be build age related; mine May/June 2019 and there has been talk on forums ( well Porsche hardly going to give us actual data ) about defects , and repeat of said defect last year.
In any case, they say ( euphemism for ..if you drag it out of them ) that it is an advisory which they are doing at next available time. Hmmmmm.... .
I'll have to check my paperwork from last week to see if they opened up a campaign on replacing my dynamic engine mounts. I do remember seeing that they ordered parts to replace the Bose loudspeakers as well as my car's water pump.
They replaced my engine mounts due to a repeated PADM error. I was told by the tech it’s a known issue with the mounts that may involve easy water intrusion. Supposedly it’s fixed now after two attempts and over three weeks with them.
Although I have never had the issue or warning, what you say is consistent with story from "my" OPC ....change mounts and add some new cover too.....
