Weight Saving Options
Old Jul 7, 2020 | 08:39 AM
russbert's Avatar
russbert
Doesn't an after market exhaust usually give you a weight savings as well? (18.5 lbs or so).
For me, if I went on a diet that would represent a nice weight savings as well. Whoops, I'd better stop eating all of that popcorn.
Old Jul 7, 2020 | 11:53 AM
markchristenson's Avatar
markchristenson
Originally Posted by gcurnew
My best guess on relative roof weights: lightest to heaviest.
The Carbon Fibre roof would be the lightest (better be considering the cost).
The second-lightest would be the standard aluminum non-opening roof (Porsche illustration shows aluminum panels in green).
https://newsroom.porsche.com/en/2019...911-18802.html
The opening metal sunroof would be appreciably heavier than the non-opening roof as it's steel rather than aluminum (according to the configurator) and also has motor and cassette.
The glass roof is likely the heaviest option: glass weighs a lot compared to aluminum or steel and there is also motor and cassette.
That would be my guess as well. I would love to know the actual weight differences. I don’t think there is a huge difference from the carbon (around 4 pounds, although it is weight up high which makes a bigger difference than 4 pounds down low). I’m guessing maybe 20 pounds additional for the steel sunroof and then maybe another 5-10 (for a total of 25-30) for the glass?
Old Jul 7, 2020 | 12:37 PM
Vintage72's Avatar
Vintage72
FOR ME, 911s with any sunroof is one of my few, absolute no gos. I understand some people love sunroofs and they should order it how they want, but go cab instead or stay coupe, don't split the baby.
Old Jul 7, 2020 | 12:46 PM
Drizz's Avatar
Drizz
Drive around by yourself vs with a passenger. Weight savings approx 110-300lbs (depending on passenger)
Old Jul 7, 2020 | 02:06 PM
Vintage72's Avatar
Vintage72
Passengers are my least favorite thing in a 911 - couldn't agree more.
Old Jul 7, 2020 | 02:14 PM
markchristenson
I remember doing autocrosses, having an instructor with me, and then for the timed runs it was just me. The braking points totally changed.
Old Jul 7, 2020 | 02:54 PM
ipse dixit's Avatar
ipse dixit
One thing to keep in mind about reducing weight that I think many people overlook is balance.
Yes, it's good to reduce weight with a lightweight battery, but then that just makes the front of the car even lighter (vis-a-vis the rear), which will throw off the cornering and braking of the car (as the stock suspension setup is tuned for a certain weight and weight distribution). Not to mention how this will affect the aero of the car at speed.
This is less of an issue when we are talking about reducing mass or weight equally from the car -- i.e., wheels or brakes -- but it is still something to consider as, again, the suspension is not necessarily setup for what can be described as not insignificant weight reduction.
Old Jul 7, 2020 | 04:52 PM
swagon's Avatar
swagon
The Exclusive wheels are the only OEM forged set for the 992, don't know the numbers, but I bet higher-end HREs or BBS in 19" would still be lighter.
Old Jul 7, 2020 | 05:10 PM
smiles11's Avatar
smiles11
This is true. A big reason why most shouldn't worry about the extra 60lb power seats; since it's weight helps offset some of the rear weight bias
Old Jul 7, 2020 | 05:14 PM
inastrangeland's Avatar
inastrangeland
Should be able to factor some the weight out using corner balancing. But that presumes height adjustable springs.
Old Jul 7, 2020 | 06:47 PM
markchristenson
One more thing to budget now :-)
Old Jul 7, 2020 | 07:10 PM
Dan Nagy's Avatar
Dan Nagy
Oh yeah, I am totally using that. “I ordered all this extra crap to properly balance my car, dear.”
Old Jul 7, 2020 | 07:15 PM
smiles11's Avatar
smiles11
Anything helps lol but I've needed a lot more than that to justify my 911's
Old Jul 7, 2020 | 08:16 PM
Antigravity's Avatar
Antigravity
Premium Sponsor
Originally Posted by markchristenson
I seem to recall a thread that showed how much weight the carbon roof saves, and thought it was around 4 pounds (3.8 sticks in my mind for some reason). I cannot find that thread any longer, despite spending a bunch of time searching.
However, that got me thinking about all the options that save weight. (If this information already exists in one place, happy to be pointed that direction and can delete this thread.)
Factory options:
Carbon roof: 30% compared to steel (IIRC 3-4 pounds)
PCCB: 40 pounds (based on some other threads I saw)
4-way vs. 14-/18-way seats: ~60 pounds
Lightweight/insulated glass: 8 pounds
Sunroof delete: ??? (this almost seems like it would a weight increase depending on which of the two sunroof options a buyer spec'd)
Manual Transmission: 77 pounds
Base interior (i.e., not full leather): ???
Aftermarket options to save weight:
Aftermarket wheels: 20-40 pounds
AntiGravity Battery: 40 pounds
Exhaust: 18 pounds (depends on specific system)
I can update this with other options/suggestions as they come up.
When you're ready to move forward on the battery just let us know and we'll make sure you're taken care of. For those that haven't seen or are wondering what the battery is all about feel free to check out our new Video below. It's a little long but informative and of course as always feel free to reach out to us with any questions you might have.
-Chad
chad@antigravitybatteries.com
Old Jul 7, 2020 | 10:05 PM
Vintage72's Avatar
Vintage72
Thank you - I love my Antigravity Battery. Easy install and no problems or codes thrown. It is a real DIY. When I put that and Soul Performance side deletes in the back of my Touring, it lost 75 lbs. without breaking a sweat. And, my battery never skipped a beat.
