H&R springs or techart
#46
Thanks. Took a few attempts to get it right. Nice thing is with HAS you can adjust when it settles. I also had an alignment done and camber is maxed out resulting in a little more negative camber than spec but not by much (-1.28 and -1.51 vs spec of -1.00 and -1.45). Before adjusting it was up to -3.0.
#47
#48
#49
#50
Did you experience any errors on dash? I’m trying to get my techart HAS installed again after a hige failure last year (ride height errors, rear diff errors and a broken heigh sensor in one corner). I located a different shop that has the proper PIWISS system this time, and hopefully it’s just a matter of inputting the new ride height on the PWISS.
![](https://cimg5.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/f87bded0_2a2c_4578_a29a_afc068e5c957_093648155e3529ae4e75ee1c2591f5de4d3f100c.jpeg)
Tanqueray86 (08-23-2022)
#51
#52
Was there anything I should point out to the mechanic for the installation/ PIWIS coding? Thanks again!
#54
I ended up paying less than 1/3 of that but I had multiple cars worked on before in same shop. So, repeat customer. I got other quotes but none higher than $1500. But some did not quote as they did not want to touch it including one Euro specialized shop where I had suspension work done on my AMG before.
#55
#56
Another one on KW HAS here.
I had TechArt springs on my 991.2 Carrera T and really wished I could dial them in properly.
That's why the HAS kit was worth it for me on this car.
![](https://i.postimg.cc/mkfM2HKd/DSC-3233-1080-copy.jpg)
The following 3 users liked this post by tourenwagen:
