I took my first drive on the freeway today and noticed a fair amount of wind noise from the drivers side door window. Has anyone else experienced this or had the problem corrected? If so what were the measures taken?
Overall very happy wth this car but need to get this resolved and a slight buzz from the dash/console area when riding over raised lane markers.
I noticed it driving home from the dealership after paying for the car - seems like it's from the mirror, not sure how this can be fixed.
Added to my list of other noises for them to look into when the world goes back to normal...
Cracking the sunroof or driving above 90 and the road noise drowns it out!
same here on my UK car. Its coming from wing mirror.. very annoying.
I have the folding mirrors, standard design mirror, and no noise...wondering if those getting noise changed something in their mirror design, or maybe don't have the folding design type?
Same issue. It's like a whistling noise. Happens at about 50 MPH or faster. I hope to get this fixed when I get back to the dealership (along with all sorts of buzzing and rattling from the passenger side door).
I get the same thing with my C2S which has the folding mirrors. I only notice it above about 80 mph. If I have the stereo playing I can't hear it. I figure this is just a design quirk that comes with owning a sports car, much like the road noise you get from the performance tires.
I had been noticing a similar buzzing noise that appeared to originate in the pax door area when driving over lane markers. I eventually traced this down to the front and rear pax seat belts. I connected the rear belts into their respective latches and placed the front pax seatbelt over the edge of the seat when not in use and the noise has stopped. I'm considering placing small felt strips underneath the buckles to see if that will effect a more permanent solution.
I understand that there are some things that are tradeoffs associated with sportscars. I don't expect luxury but I have most recently owned three different model year Audi R8's a Ferrari 458 and a Lamborghini Aventador. They were all quite solid and devoid of rattles and wind noise. I don't think that this level of quality is above Porsche capabilities or buyers expectations.
Sounds like window leaking air or a gasket somewhere. Could be rubber is off a little or window needs slight adjustment. A friend of mine had exact same problem on his NSX, It was the rubber seal against the glass and a factory defect that couldnt be fixed nor did acura care to fix it. Common problem for those guys.
I have a theory that this wind noise might be present on all cars, but the reason some don't hear it is two fold..
1. Some of us have a higher threshold for what we expect as a normal amount of wind noise from the mirrors.
2. And this is more likely the case... some cars are allowing more wind noise to pass thru the window/door seals..
Coming out of an 2019 Aston Vantage, my 2020 S cab seems amazingly quiet. The Aston had a differential that whined above 50mph (seems like a common complaint) wind noise from the mirrors and sometimes from the windows. I took my car back several times to the dealer and they were all deemed "normal" Fortunately my car was finally decloared a lemon and I am now in a 2020 Cab S
