Another Noob ?
Brad911 (03-14-2020)
I wired my camera directly into the drivers side fuse panel. The far forward mini fuse bus is accessory power and the rear mini bus is direct battery. Didn’t even check the standard fuse in the middle. I just used a couple of fuse taps you can find on amazon or any auto parts store. Fuse taps are nice because they don’t modify the car and can be removed in seconds without any permanent change to the vehicle.
Brad911 (03-15-2020)
