Sliplo
I have it on my Huracan. It's saved several parts of the front bumper over the last year. I've had to replace a couple pieces and they sort of suck to deal with until you blast them on social media. That's my only gripe.
I think not "nonsense." Aerodynamics 101. The airflow management under a high-performance car works in concert with body aero. Even the slight change in the front lip depth and angle of attack on a SPASM-equipped car is designed to affect aero. Anything under the leading edge of the lip of a car with carefully designed underbody trays would totally mess up the airflow under the car. Would you feel it at 70 mph? Probably not. At 160 mph, yes...unless of course the 3m tape has already let go loll.
furthermore it has no affect on the lip.. this all mounts up above that area and well back of it.
phangstaz (02-25-2020)
Never said it had anything to do with the lip. I used the SPASM lip as an example of how a slight change affects aero. Porsche has done the wind tunnel testing to ensure under-body airflow is as clean as possible, through to the back of the car where the air exit is managed through the rear valance/diffuser; this product will disrupt that airflow. The question is how much, and to what degree it will upset aero balance at speed. When I was racing, even small changes to front and rear spoiler profile (and one weekend where less-than-optimal positioning of brake ducting disrupted the underbody airflow) affected high speed-stability. On the street, most owners would never be impacted; on the track (or on a non speed-restricted road) at 125 to 190+ mph is a different story.
People are free to put whatever products they want on their car, but I'm of the mind that Porsche aero is very finely tuned and putting anything in the airflow without knowing the precise effect it will have is pure folly. If a part is race-tested or there is wind tunnel data made available, the effect may not be problematic. My point, with which you clearly disagree, is these Mickey Mouse stick-ons will affect underbody airflow and thus have no place on a 992 or any other modern high-performance car with sophisticated aero management.
The following 2 users liked this post by gcurnew:
detansinn (02-25-2020),
Russ Bryant (02-26-2020)
