HomeLink Profile from small 4 tile screen!?
I can't seem to get this button to do anything. Can anyone explain what this does or is supposed to do please? Was hoping it would bring up HomeLink option to open/close garage (yes I do have HomeLink on one of my three hard buttons). Thanks much!
I have this configured on my home screen. When selected it will take you to another screen with 3 choices, the top one being “current home link profiles”, select this and all your currently programmed profiles will be listed, (I only have 1), touching the chosen profile will send the signal.
I have it configured in my home screen and the pop up right menu. However sometimes it takes me to the configuration screen and other times it has the preconfigured homelink button there which allows me to skip multiple presses. Still haven’t figured out how or why it isn’t aways the preconfigured setting. Likely GPS related stuff not quite working.
yes. This tile just calls up the Homelink menu. You then have multiple touches to open profiles, select your required profile, and then send the signal. Useless....
However, (must credit detannsin here) if you use a double-width tile and program it for use with HomeLink, the tile lists local profiles on it when you approach a gate/door. This works.
Still a long way from perfect but better than nothing.
NigelPlays (02-14-2020)
I'll continue the homelink saga...
So my gps triggered homelink button is unreliable also, and I configured the double width widget on the home screen.
Sometime it shows my "homelink 1" trigger button, most times it still only wants to take me to the config menu.
Deleted the gps feature, no change.
Amazingly when I'm forced to the config screen it takes up to six (6) button presses (if I also have to exit the camera screen) to get to my "homelink 1" trigger button (yes I counted them)!
I know there are simpler ways to get there but why doesn't my trigger button stay available on the damn widget? Anyone have a clue?
deetz307 (04-26-2020)
I have a large tile configured on my home screen as well; however, if GPS location does not automatically display my configured Homelink profiles (usually 50% of the time) - then I press the tile and takes me into the "configure" process for a new Homelink profile (which I don't want) and I have to cancel out of a configuration process (2 addt'l clicks) to get to the HomeLink screen and then select the profile I want and press "send signal".
Is this how it works for everyone when the GPS identification fails or do I have the wrong home screen tile?
I only have one joker button and was using that to display cameras - but may have to switch to HomeLink if that works better than the tile.
Maybe this is a security feature - anyone who steals my car will have a hard time getting into my garage.
(on the point of a software company making a car - 5 years of driving a Tesla and I have yet to press the homelink button on the screen - GPS automatically opens the door every single time I approach my garage).
