why the base 992 looking weird ?
Hi im new with Porsche and my first car from Porsche 992 and i will get my car next month from dealer.
my question i ordered vossen rims HF 5 20x9 21x12
but is the S lower then the base model ?
and do i need lower kits ?
G650 (01-23-2020)
from factory they will add it (10mm) because my car will come with Aerokits so i will get it in February
Being an owner of both sets of wheels, they’re not the same. In fact, the PCM has a setting to select 19/20 and 20/21 wheels to accommodate the difference in circumference. My 19/20 winter wheels are the Base Carrera wheels. My summer wheels are 20/21 Spyder Design wheels.
I went to the garage and measured my fronts. My summer 20" fronts with OEM tires (26 1/4") are nearly 3/4" larger in diameter than the winter setup. A properly inflated low profile tire isn't sagging 3/4" with the weight of the car. Of course, proper measurement would be both tires off of the car, but that's not worth the effort. It's not the "same diameter" or "delta 1mm".
I don't feel like unstacking the fronts to measure the rears, but you can bet that the delta there is even bigger. The bigger wheels are bigger, even with tires.
Side note: Porsche claims the same offsets for the Base Carrera wheels and the 20/21 wheels, but they're clearly different and obvious when installed on the car.
G650 (01-23-2020)
But the overall diameters between the winter/summer tires are the same. All the tires charts give the same out.dia. between 305/30-21 and 295/35-20. it’s the perfect match and same thing for the front tire size. But between summer tires and winter tires there’s certainly a difference because the winter tires have a more depth tread than the summer tires
Aside from how the tire fits to the rim, the tire size isn't going to give you enough information to establish the overall dimensions of the tires. You can have two tires that are the same "size" from different manufacturers, but be different in overall size and shape -- especially when it comes to the sidewall design. In lowered applications, one brand of tire may rub where another brand may not, even tires ostensibly of the same size. Heck, if you want to complicate things, a 295 tire can fit on a rim that otherwise takes a 305 and the result would be a different profile.... and we haven't even touched the stretching community. :P
