California Duster
Agreed. Used them for 20 years as described here. No scratches or swirls — the thick fibers lift dust away from the clear coat.
I would never use one for anything other than removing a fine coat of surface dust. They’re not designed for heavier cleaning (that’s why they’re called the California Car DUSTER). They will scratch paint if used improperly.
992Sam (01-21-2020)
NEVER “dust” your car!!! Rinse it off first. Then blow dry. You will scratch your paint. Or swirl it. This is what dealerships do and hence you have swirls.
Received 5,413 Likes
Hence the name ... California Duster
And 2020, amen to using one to remove pollen. Same deal here in North Texas. March through June, our cars gets lightly kissed by a coat of greenish-yellow pollen every time they're rolled out of the garage. I use the duster for that too. If I was really smart, I'd do a PTS in Snot Green for our 992. Problem solved.
Only if you don't know what you're doing, or are using a poorly designed product. Sorry, decades of direct experience says otherwise.
1. Never ever use automatic car washers
2. Always protect your car with a dilm
3. Nano coatings are amazing and a must do
4. Never use dusters or microfiber cloths on a dry car to dust it. You will scratch it.
5. Always blow dry your car. Simple leaf blower is fine. If your car is nano coated or well waxed the water will bead off quickly.
6. Do your own car. No one cares for it more than you. If not make sure whoever you use follows all of these guidelines
7. Use a bucket with a grate at the bottom so dirt settles at the bottom and doesn’t get on your wash mitt or cloth
8. Always use a microfiber wash mitt.
9. Try to use a high pressure sprayer or strong water sprayer on your car prior to washing to get off all dirt.
I know this sounds like a lot but it only takes me 30 minutes to wash and dry a 911 at the most. Especially when it is coated.
My cars are always scratch and swirl free. I only buy darker cars and my finish looks like a mirror.
![](https://cimg5.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/img_0015_524cba42b0d493bc17cead52911480fcf56d790a.jpg)
![](https://cimg7.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/img_0016_0aa8002c9e7ff5e6874f7dfc5965daf6e86bc045.jpg)
![](https://cimg4.ibsrv.net/gimg/rennlist.com-vbulletin/349x252/69a05332_cae5_4816_9162_98c33914299a_c6e4d5afd44aebf018b804e388d3dcde68dfd47f.jpeg)
![](https://cimg5.ibsrv.net/gimg/rennlist.com-vbulletin/1500x2000/f17a5f63_8a65_4e78_8dc2_168f62ae3c24_8ae3ecfdafd1731daca2bad2caea653c3bed0a79.jpeg)
![](https://cimg6.ibsrv.net/gimg/rennlist.com-vbulletin/1500x2000/a740f14f_cc7f_4b5c_af62_4aa41e3a321f_e0546c6a357a1e24677f91b6f2f230c5818341d2.jpeg)
What he said.
I only use the mini California Duster for a quick swipe of the dash and console between details and never on the paint.
Huge believer in the 2 bucket with grates wash method, blow dry the car and only wipe it down as a final with a mist of CQuartz Elixir or Reload after the wash.
I never use a car wash and under the penalty of death do not allow the dealer to wash it.
I most likely spend to much on product and towels for the outside and inside detailing but my car is 5 years old with over 30k miles and still looks showroom with a few road rash badges of courage.
NOSUB2T (01-23-2020)
What he said.
Huge believer in the 2 bucket with grates wash method, blow dry the car and only wipe it down as a final with a mist of CQuartz Elixir or Reload.
NOSUB2T (01-24-2020)
I guess I'm in the minority. I've used CA Dusters for years on numerous cars. NEVER an issue with scratches/swirls. Use as directed on DUST/pollen ONLY and you'll be just fine. Just my 2 cents worth.
![popcorn](https://rennlist.com/forums/images/smilies/popcorn.gif)
Administrator - "Tyson"
I wouldn't have wanted to own any of my black cars without one.
