Possible to change interior trim to CF?
Is it possible to change out the standard plastic trim around the cup holder, dash and doors to Carbon Fiber? If so, is this something that can be done at home or only through Porsche? Cost? Thanks in advance!
Former Vendor
The 992 trim pieces on the dashboard and center console (ashtray surround) are fairly easy replaceable. The parts are around $1,000 for the two dashboard pieces and around $340 for the center console trim.
The doors are the tricky parts. Just like on the 991 the door panels are only available as complete pieces and you cannot get the (in this case Carbon) trim separately. The Porsche Parts System only shows ‘Door Panel - can only be ordered via special proc.’ - so pricing will likely be in the same ball park as 991 (around $2,000 to $2,500).
However, the door panels can be disassembled and the trim can be redone.
Where are you located? We can help to source the parts for you - or create a unique trim package for you... Maybe colored carbon trim?! Or how about a Houndstooth trim instead of carbon? 😇🏁
JHesketh (01-14-2020)
