Microfiber Towels
Enjoy. Very-very knowledgeable guys over here:
https://rennlist.com/forums/concours-and-car-care-86/
363ny (01-09-2020)
WOW! I just looked this up! This looks amazing! I definitely need to order this. I get the water lines after a wash and it hurts when I see them! This is a game changer. Thanks so much for sharing!!
Caliporsche (01-07-2020)
From: VA, NC and SC . Up and down the damn road too much
A normal leaf blower works pretty good as well. The key is to make sure you wash and rinse the car with soft water. This can make all the difference in the world when it comes to drying and water spots.
That plus the fact that you will reduce a towel touching your car as you dry it.
363ny (01-09-2020)
I bought one of the Master Blaster dryers after reading Lex's recommendation. Beyond the incredible drying capabilities, it is the tool for thorough interior cleaning. Vacuum your interior as best as you can and then use the Blaster to blow out every single, little piece of detritus that your vacuum just can't get. Under the seats, in the footwells, in between the seats and the center console, through the HVAC vents...the thing is far less unwieldy in a small car than a leaf blower, and your car will look cleaner than it ever has with a regular shop vac.
Mark in Baltimore (01-07-2020)
Yes, really what I do is use a blower and finish off with the happy ending towels. I also use a water softener system. I made a video about it on youtube if you search for Church of Porsche its the one titled don't believe everything you see on YouTube.
