Playing around with the configurator in 360 - I noticed that:
1. If you select SPASM -10mm it adds the front lip - but the car does not sit lower
2. Now select Front Axel Lift (FAL) and you see a slight lowering of the car
3. No switching On/Off SPASM does not do anything
4. Remove FAL and car goes back up and SPASM switch work again.
Best way to see this is to remove the background and look closely at the gap at the wheels - pic below
I suspect the assumption is that FAL is combined with SPASM (and that is what the configurator shows) - but it could also mean that adding FAL lowers the car further. I know not likely - but hey - something to worry about
SPASM lowers car by 10 mm, adds front spoiler and higher angle of rear spoiler. FAL does not give you lower ride height, that would be the complete opposite of what it's supposed to do.
My 360 configurator shows the SPASM changes correctly.
Agreed that this is nothing to worry about - it must be a bug on the configurator (I'm not making this up - as you can see both have the SPASM lip but the bottom pic sits lower). I use the Dutch locale - which one do you use?
