992 Cabriolet....chassis flex causing horrible noise?
Put about 500 miles on my wife’s 992 C2S cab, a horrendous bang happens when making left hand turns (only left hand turns and when approaching slight inclines with left tire touching first) driveways or parking lots. Sounds like chassis flex pop with something low and forward of center tunnel? Never have had a cab version of any gen so not sure if they really are that flexible (I’ve driven other manufactures convertibles that are wobbly messes). Anyone else with cab experience this or maybe with 991 gen? Scheduling trip to dealer this coming week to have them check it out but it’s disconcerting.
I cant imagine it would be chassis flex but could be something else that at that kind of angle pops, thats def something to have them investigate, thats not normal at all.
Not normal. Have it checked out.
I know it's a cab, but seriously they've made the 911 chassis so stiff that I get one wheel up in the air when transitioning onto an incline. What's your speed when this happens? Are you turning the steering wheel or just holding your steering angle while rolling onto an incline? If it happens while you're at a snails pace then something isn't bolted in... Or maybe they left the shipping pucks in place?
If you can capture it on your phone it'll help you ensure that the dealer gets it solved the first time - you don't want to be sent home a few times with "unable to duplicate problem" before they actually fix it.
You're experiencing what's commonly called "Ackermann chatter" or "tire skip" - a result of performance cars having reduced steering Ackermann geometry in comparison to normal sedans, SUVs, etc. This causes the chatter that you hear when at full lock, especially at low parking-lot-type speeds and at cold temps.
It's normal.....on Turbo S website but those cars are all wheel drive so maybe different scenario but went to tech session and explained as normal on these cars rear or all wheel....
The following 2 users liked this post by abiazis:
NigelPlays (11-30-2019),
Senna01 (12-02-2019)
no it’s not tire skip and the sound doesn’t duplicate this condition, this is a single event pop or thud like someone has struck one blow to bottom of chassis with a hammer. And only when chassis is loaded in transition. Wheels can be turned or straight but if drivers side tire enters incline before passenger side tire this happens regardless of steering angle. Ackerman chatter will occur regardless of direction you are turning, my condition ONLY happens during left turn approaches.
I put car up on lift today at the shop I use for track prep...no blocks left in suspension and nothing obvious that stands out. I’m still fearing chassis issue but we’ll see if the brain trust at dealership can get to bottom of it.
Weirdly I currently have a 992 C2S Cab and this has been the least problematic out of all my 911's to date.
