Auto stop/start in “Normal” mode
One of the beauties of the 991.1 generation - you can disengage auto start/stop with one press of a very analog button and the function will be off indefinitely, as in, forever if you so choose. Ahh, the good old days...
The following 3 users liked this post by Porsche911GTS'16:
Sorry , I forgot the audience. Sarcasm.
For those of us without Sport Chrono, the easiest way is to have it as a short cut on your home page. It's the first thing i do, once thing spool up on the screen, which onto itself, is annoying....but those brakes, speed, handling......
To be honest I think it's better as a shortcut on the screen anyways; then you can use the standard/base mode as you're getting out of the garage and the car is warming up mode, individual for a blend of features that differ from the base and sport modes, and the sport/sport plus for their features. If you always switch out of standard to bypass start/stop you've essentially lost a mode.
Its a Car made in the EU ( or the sate of greater German if they get their way) and that is part of the regulatory requirement here , right wrong for those unable to adapt. One big "button" configured one "home" screen and its a zero thing.
Personally I don't miss the hand crank for the engine and being forced to accept that electric starter nonsense
![](https://cimg6.ibsrv.net/gimg/rennlist.com-vbulletin/600x381/well_thats_gotta_288c40628f191339b88f6f5940bd6e8dbd2bc72a.jpg)
When I first started the car today, and once thereafter, both the Auto Stop/Start widget and the Apple Car Play widget were instantly there, fully present. In the past, i would have to wait 45 seconds for both of these to spool up. Anyone else experiencing this?
I notice the Mclaren people sometimes mentioning in on forum , that their cars maybe do not like switch straight to engine start without a reasonable pause when turning on the ignition. Like their cars need to settle a moment with all the advanced systems trying to get running properly ...before engine start. Maybe our 992 have a little of this ? . Since I am not usually in some bursting hurry to get going, I always tend to turn on and wait at least 10 seconds while the PCM gets its act together ..then start. The pursuit and desire for ever increasing functions and complexity and decreasing roll out schedules, somewhat guarantees issues. This is my area of work .
The LEDs on the M and P buttons ( in particular M) have a life of their own in my car whether they want to show or not . The instrument display always shows correct mode and the control always function . That and a couple of rattles need attending too when it 1st goes back to Porsche ( which now that weather has turned seems like good time )
Yes you can. Those “quick access “ buttons can be set to turn on/off the auto start/stop.
The other easy way is to configure your Individual driving mode. You can select chassis settings, exhaust, start/stop,... Then save those as your Individual settings. You could just duplicate the Normal driving mode settings with auto start/stop disabled. When you start the car, just flip the driving mode from Normal to Individual.
I've just programmed by "Individual" setting to full normal mode but with the auto start/stop disabled. That is probably the easiest way, but you do have the annoyance of having to turn the dial all the way to individual. I wish they would have put it to the left of "Normal" mode.
I like the feature, but mine seems to only work intermittently and I get the icon on the digital dash. Is there a way to make it shut off at stops consistently?
Fullyield (07-03-2022)
Consider that when your car is hot or you are in heavy stop and go traffic whether you want the oil/coolant flow to/from your turbos interrupted even if for only seconds or a few minutes maybe. I disable A/S/S for that reason. Personally, I am less concerned about My MPG/emissions than my turbos…..but that’s just me. Others opinions may differ.
Having lived in Germany from 89' - 91', Germans would routinely shut their cars off at stop lights... A/C be damned if they even had A/C. So the idea is not new to Germans. I don't mind A/S/S except that it engages when I don't want it to - for example when I come to a momentary stop on my driveway. Otherwise, I don't mind it. Thus, in my22 I have it assigned to a button so that I can turn it on/off.
