Auto stop/start in “Normal” mode
I hate that Porsche denies me the option of turning auto stop/ start off in Normal mode. When driving at posted speed limits around town the PDK rarely shifts any higher than 5th gear. Sport mode shift points are too long. Yeah, I know all the haters will criticize my driving habits. I have had it over 110 and Sport plus is a hoot but sometimes I just want to cruise along and collect admiring glances! (And Save Gas!)
You can turn off the auto start/stop when in Normal mode. In the PCM select the Car menu and then the Drive menu to find the start/stop disable. It is a hassle to navigate to so I customized my Home screen and put a shortcut there to disable it.
Hope this helps!
Hope this helps!
The following 4 users liked this post by Tom911ATL:
Can you customize the “favorite” toggle switch to turn on/off the start/stop function?
I disable mine from the Home screen with every startup. It's very frustrating that you can't have it disabled by default, but Porsche made lots of crazy fuel economy/emissions promises to regulators, so, it's not that surprising.
The other easy way is to configure your Individual driving mode. You can select chassis settings, exhaust, start/stop,... Then save those as your Individual settings. You could just duplicate the Normal driving mode settings with auto start/stop disabled. When you start the car, just flip the driving mode from Normal to Individual.
Thanks for the feedback. Hopefully the favorite toggle will be able to have it as an option. Fingers crossed.
But it looks like the individual mode looks to be the most common way to fix it. I’d ultimately like to have my individual mode customized to be identical to normal mode, except auto start/stop feature disabled.
It can be added to favorites if they program it in, not sure it's the most efficient use of those shortcuts since ideally you'd put something there used more than once a startup. On the other hand the EPA requires the car to default to the setting used for certification at every startup so Porsche had no choice but set up the car that way. BMW got around this by presenting data to the EPA showing that most owners immediately turned it off upon startup and got an exemption allowing the dealership to turn it off at the owners request which you can have it done before you drive off the lot. So I get they need to improve their numbers but what I don't get is that to my knowledge no one else has asked for or obtained the same exemption. Porsche could do it just as easily as BMW did and it's a little baffling to me that they haven't gone there yet.
I've just programmed by "Individual" setting to full normal mode but with the auto start/stop disabled. That is probably the easiest way, but you do have the annoyance of having to turn the dial all the way to individual. I wish they would have put it to the left of "Normal" mode.
jkautz (11-18-2019)
It seems like the real problem here is that there is no physical button for A.S.S. It’s the same with the idiotic Homelink
sapman (04-18-2023)
Its a Car made in the EU ( or the sate of greater German if they get their way) and that is part of the regulatory requirement here , right wrong for those unable to adapt. One big "button" configured one "home" screen and its a zero thing.
Personally I don't miss the hand crank for the engine and being forced to accept that electric starter nonsense
verstraete (11-19-2019)
