992 Turbo and Turbo S 2019-Current
Title: 2022 992 Turbo S PCCB – 4927 vs 8286 (front) + 4925 (rear) + Pagid RSC1 confir
Old Mar 23, 2026 | 05:01 PM
georgi9111's Avatar
georgi9111
Default Title: 2022 992 Turbo S PCCB – 4927 vs 8286 (front) + 4925 (rear) + Pagid RSC1 confir
Hi all,
I’m trying to confirm the correct Pagid pad shapes (front and rear) before ordering RSC1, as I’m getting conflicting info from different suppliers.
Car:
  • 2022 Porsche 992 Turbo S
  • PCCB (ceramic brakes)
  • OEM front pads: 992 698 151 L
  • OEM rear pads: 992 698 451 L
Pagid shapes I’ve identified:
Front:
  • 4927 → 198 × 88 mm
  • 8286 → 195 × 101 mm
Rear:
  • 4925 (commonly listed for PCCB Turbo/GT3 platforms)
Clearly 4927 vs 8286 are very different, so they shouldn’t fit the same caliper.
Confusion:
  • Gieffe / Atomic → list 4927 (RSC1) for 992 Turbo S PCCB
  • Hinz Motorsport → sells RSC1 in shape 8286 also labeled for 992 Turbo S PCCB
Questions:
  1. Can anyone with a 2022 992 Turbo S PCCB confirm their actual pad shapes:
    • Front: 4927 or 8286?
    • Rear: 4925?
  2. Has anyone physically removed/measured pads on this exact setup?
  3. Are there two different front PCCB calipers on 992 Turbo S, depending on production batch or supplier?
  4. Does OEM:
    • 992 698 151 L → map to 4927?
    • 992 698 451 L → map to 4925?
  5. Any real-world feedback on Pagid RSC1 vs OEM on PCCB:
    • Disc wear
    • Noise
    • Daily drivability
Goal:
Run Pagid RSC1 for occasional track use, but avoid ordering the wrong pad shape.
Appreciate any confirmed data, photos, or PET screenshots.
Thanks!
Old Mar 26, 2026 | 06:51 AM
hu992tts's Avatar
hu992tts
Deleted
Old Mar 26, 2026 | 03:38 PM
msv's Avatar
msv
8286 front
4925 rear
4927 is a 6-piston pad for 410x36mm PCCB applications
