992 TT(S) Track Build?
I would get the TT with PCCBs and the Lightweight Pkg.
If you replace the stock Turbochargers with an upgrade, supposedly the TT engine is otherwise fundamentally identical to a TTS, so a Turbo-upgraded TT is the same as a Turbo-upgraded TTS.
What I want to know is - are the steel brakes superior to the PCCBs for track driving? I don't do much of that, but that is what I gather from some comments on here.
PCCB or not
PDCC or not
L76
The composite brakes do not last long if the car is used for heavy track use. Most guys run steel brakes for this reason. They are $$$ to replace.
tires
wheels
rotors
pads
running stage 2 mods on 91/93
guess I’ll have to live with the PDCC… this was my only reason for TT over TTS (as I plan on running the PCCBs only on road). Just “got over it” and bought the TTS anyway. Anyone got ideas how to turn it off/delete on TTS? 🤣
Cheers,
L76
I wouldn't bother with the steel brakes - if you change the pads at 50%, the carbon disks will last a very long time, and you have the benefit of lower weight and better (arguably) performance - plus you don't have the go through the hassle of swapping them. For replacements, I just bought a complete "conversion" kit for my GT3 for $17K - that includes the rotors, pads and calipers! I've also heard good things about the Surface Transforms replacement disks . . .
https://www.suncoastparts.com/produc...92gt3pccb.html
Location: Mid-Atlantic (on land, not in the middle of the ocean)
Received 4,448 Likes
I tracked my 992 TTS. If you replace the pads at 50%, they last less than 2 track days. For me, that’s a dealbreaker in terms of hassle and cost. My understanding is that iron rotor conversion is not currently available for these brakes. So if the car will be tracked, I think it has to be TT with regular brakes, which is unfortunate because I love the feel of PCCB.
I vacillated on this when deciding TTS vs. TT on my build. wrt to 70hp... that can be overcome with tune/turbos/etc. right? wrt to PCCB - is this your preference (?) as performance differences ($$ aside) between PCCB and iron rotors from what I have seen is still open to the jury. I've seen arguments both ways. As for PDCC... there's no way to "turn it off" in the TTS. Assuming your conclusion is that it is a performance degradation? Any ideas of performance degradation of PDCC equipped vs. non equipped?
Thx,
L76
Thx,
L76
PCCB do not offer a meaningful braking performance advantage over iron rotors with track pads. All reliable info I have seen this far shows that PCCB rotors wear about just as fast as iron rotors with track use. With the higher cost of PCCB pads and rotors, it significantly increases consumable costs. If the different feel and unsprung mass reduction are worth the extra cost, it is up to you.
I’ve read reports from pro-drivers that say that PDCC makes the handling less predictable at the limit, particularly over bumps or curbs.
if priority is purity of feel while driving on track, i think way to go is a carrera t and then upgrade turbos to 550hp. thats basically a rwd tt with option of stick shift too. lots of youtube videos of these turbo swaps and seem pretty straight forward
I did not get a chance to drive a -T on track, but I did drive a base C4, a stock -S, a modified -S, a LW GTS, a 4-GTS and obviously my own TT. Of all those, I find my TT to be the most entertaining to drive on track. The next level up for track fun IMO are GT2/3.
Pad Bender (03-15-2024)
Yes, turbo upgrade and tune would equal TT-S power potential. But I want to maintain factory warranty, so this is a no-go for me. Both my turbos and wastegates had to replaced last spring, I am sure glad it was covered.
On a very cold morning, when I started the car, the waste gates made a screeching sound at the end of the cold start sequence. From then on, I got an intermittent check engine light. In the spring, when I brought the car in for service, I asked that they check for faults regarding the check engine light. They said it was due to faulty waste gates and that Porsche had a new part number. When they attempted to remove the waste gates, they stripped the threads in the turbos and therefore also needed to replace the turbos.
Makes sense, thanks for sharing!
