I changed cats before I ever tuned and never got a CE light so, I think it depends on the cat. I use Kline. As far as catless, I have had this discussion many times. The 200 and 100 cell cats flow something like 95% and 96% and well as a straight pipe, so unless you are looking for that extra 1hp (or whatever) there is no reason to go straight pipe. The negatives I found with straight pipes are the strong smell of raw gas in my garage after going for any drive. The 100% chance of throwing a CE light without a tune. The insanely loud sound (especially at cold start) with straight pipes and the fact that they are ILLEGAL in all 50 states, but that is the least of my concerns
...Just changing the cats may be enough sound and increase in power to just stop right there...
This was absolutely true on my 991 Turbo S... I had run at least 7 different permutations of exhausts and cats (or bypasses), and while I settled on a Soul exhaust with cat bypass, my second favorite was just the stock exhaust with cat bypass.
I'd also suggest trying to listen/drive as many combos as you can in person! Combos that others have loved on their cars were absolutely not for me, and likely vice versa. Likewise, youtube videos are largely useless IMHO for determining if you will like an exhaust.
Given the extremely high cost of many of these setups, it might be worth investing a bit of travel budget into hearing some in person before you buy something that you potentially won't love.
IDK if it's your verbiage or not,, but a center replacement alone will not cause any CELs. Changing cats will more than likely throw CELs according to my understanding for > MY2021.
Who on earth spends all that money to change the center muffler and doesnt change the cats? Whether it's the cats alone or the cats in conjunction with the muffler delete, everyone I know gets a CEL when changing over the exhaust, EVERYONE. Thats why I asked to see if anyone who has done it on 992 TTS has experienced this. Anyone in the NY area with a TTS that has changed their exhaust I would love to get a listen or drive along. The drone has kept me away from even considering changing the muffler section. Wont do that again...
I've changed out just the center coupled with a valve controller. The reason I changed out the exhaust was per poll answers from fellow rennlisters who said the car would be louder with exhaust change vs cat change. It should be noted this was for a 992 GTS.
I moved the parts over to my current TTS and feel it's not as loud. Could be in my head. So I'm currently debating cats.
If you change cats I state..."eventually you may get a CEL sometimes"...992s are sensitive creatures. My first one came after months when pulling hard in frigid weather.
I have the IPE Titanium exhaust with 200 cell cats, with the valves open there is a tad bit of drone around 2500 but it isn't bad enough for me to complain about it, with them closed there is none.
anyone who says their favorite brand of aftermarket exhaust/CAT does not drone is not being truthful since they all do. even stock has drone albeit very small. tuned out the CEL on my car after concluding there is no other way. i used to carry a small scanner to clear the CEL but it was getting a bit much to do it every few days. Even with tune i still get CEL if i track the car hard and once i let the car cool down and clear the CEL everything goes back to normal. as others indicated the 992 is just way too sensitive after adding exhaust + CAT.
Hi all. If anyone would like to give Kline a shot we are proud to be their largest stocking dealer world-wide and offer Rennlist specials. We have several options in stock from sound/performance level to material and catalytic section options. Even carbon tips and we pride ourselves on our FULL guarantee and customer support
