Leaking oil pan - Day 1
you need to look for another dealership either now or down the line
buying a brand new car that costs 250 k and having oil leak within couple of days from delivery and they tell you to drive it and can't get you in for two weeks. That is poor customer service
Car have an issue from factory which can happen but dealer response is worse than the issue itself
proper response should have been
our apologies
this is a loaner : Panamera or Taycan
and will get your car in within a day
our apologies
Tupper (06-21-2023)
^ Correct, terrible service and dealer. All too common now. Google review their butt.
The following 2 users liked this post by Angryinch:
Tupper (06-21-2023),
usctrojanGT3 (10-12-2023)
Yup. I am amazed that you were told to keep driving, AND you still did. You should have had it flatbedded to the dealer. Actually, a different dealer, because the dealer who told you that is full of idiots and I wouldn’t want them anywhere near my car
Since the leak in the top of the oilpan there is still oil in the engine it just leaks out when its hot.
No flat bed service around, they even topped the oil up and drove it to their other PC abt 30min way as they are the ones with a free slot next week for service.
My porsche login is nice to have, you can see a lot of info there. The driver side window as been rolled down for days now and they have put like 50 km on the car so far.
Lets just say I'm not finished with my conversion with the dealership yet.
This is a problem with many new Turbo S coming off the line. Supposedly a gasket issue (green gasket) on the oil pan. Car will leak on both sides of the engine, often two puddles. Porsche is mum about the issue but the volume dealers know what is going on. My dealer has seen at least 4 of these same problems with 2022-2023 Turbo S engines.
At around 500 Km mark, half of which were on the day this leak happened. Same Green seals, now replaced with Black. It's a small rectangular seal and gets cracked at the end, leaking oil. There are two such seals on both sides. These are different from the main seals. In our case, only one had gone bad, so there was less oil leak. Maybe Porsche has changed the vendor or a particular batch of seals is wrong; either way- Unacceptable. Where is the QC? They boast about doing checks on batches and whatnot.
I was worried if there was an external reason (stone or hit from below due to clearance), and then I came to this thread. Thanks to your clear post, I could reason with the dealership. Whatever you have mentioned is 100% correct and happening on almost all Turbo-S.
If Porsche had made a recall and corrected this known issue, I would have been upset, but not so much as now. If someone wants to hide known issues from the customers, waiting for them to suffer and report and correct- Sorry, but that's not how it should be.
Have almost decided to get rid of this thing; maybe Porsche is the new Skoda from the Eighties.
![](https://cimg5.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/img_5134_37ea22252aa8d5122b23040c6e2dd65cc10a33bd.jpeg)
![](https://cimg7.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/img_5135_78cc85043e652267aa91a1c6859f95d529554eb7.jpeg)
Almost all are leaking oil?
So 95% are leaking oil?
Not a drop here.
I didn’t read your other thread, but it sounds like you need to take a deep breathe. It’s a gasket, replace it and move on.
Not a drop here.
abiazis (10-14-2023),
turbanator911 (10-12-2023)
Mine is April 23 built, similar to OP, so a particular period is affected, and Porsche won't accept or share what is affected. I am more pissed due to how Porsche handles a known problem than the problem itself, which is possible with any manufacturer. I know at least one more incident here that got delivered in April; that car also had this exact issue. Porsche sells very low numbers in our market, so my answer was in that context. Glad, your's working as intended.
The car has been to the workshop twice in less than a month of ownership, on a flatbed, but apparently, the replacement of Turbo, engine gaskets, coolant, and engine oil, besides all the plumbing, is regular with such things, and I should not bother
- Right.
How about this from last night: while returning from the workshop, my car was running low on fuel, and since it was not a regular pump (yeah, we have to be choosy here), I added only 10 Litres. There was no change in the distance to empty or the fuel indicator. No changes even this morning, and I was thinking about something wrong with the Pump. I added another 10 Ltrs an hour back, from a different pump, and the fuel gauge bumped closer to half with DTE - 220 Km. So, is this also a regular feature on the Porsche or am I the lucky guy?
I am selling or sold over 20 (2021-2023) turbo or turbo s's, have not seen one leak so far, seen pics on this forum of cars that have leaked oil, just have not seen it myself, yet
I will be very grateful if you can find the probable reasons for such a failure, if that's possible somehow. My dealer is clueless. Or is there a way, I can ask Porsche directly?
Reason for failure, Porsche purchases parts for parts supplier, supplier had a bad batch or QC issue that made it onto a few cars. It happens… as long as the part was switched and fixed, not a huge concern, this is why you have warranty.
I have had the same issue with my fuel tank. If you put 10L in when it’s low, sometimes it doesn’t register it on the gauge. Likely because there is two sides to the tank and a transfer pump. Manufacture doesn’t think many will pump only 10L so could be a design flaw.
Benz had an engine, very common 6.3 V8. The head bolt female torx design caused a weak spot, the head bolts would pop off inside the engine while running. Now that is cause for concern. A leaky gasket, not so much, easy fix.
Sounds like some don’t have much mechanical knowledge and expect these cars to be flawless. All manufacturers are taking parts they buy and assembling their cars. There is bound to be issues here and there, it’s simply the nature of things.
Fill your car with gas the gauge will work, fix the gasket and drive it. If you don’t enjoy it, sell it. Be fortunate you’re in the position to be even complaining about such things, it’s just a gasket.
Andrew Acree (10-12-2023),
Sounds like some don’t have much mechanical knowledge and expect these cars to be flawless..
My TT less than 2 weeks old with an oil leak. Car was at the dealer for 2 weeks and finally got it back. Said the oil gasket was the issue. Let’s hope there are no more issues.
The following 3 users liked this post by Nick44:
