IPD plenum
….As far as which platform I am referring to, I am referring to BOTH the current 992 and previous 991. I had a 991 Targa that produced more HP and torque than a Turbo S and had a stock plenum. My car was the one that was so powerful that I hit the ECU limiter during shifts so the tunes had to be made less aggressive by Cobb…The 992 flows even better than the 991 and I stand behind the negligible to no gains from these plenums over stock.
Sorry, but I don't buy that IPD Plenums achieve a single thing except to part one from their money.
I have never seen any independent third party (that doesn't stand to gain from their sale) show any gains from them. In fact, some time ago I started a thread in the regular 992 forum about this topic asking about this and I got crickets.
The only information I could find was a video that I posted where a 997 with an IPD plenum was run on a dyno. Compared to stock, no gain. I'd love to be proven wrong, but I still keep hearing crickets.
intake restrictions should show up on a dyno as choking the area of highest volume of flow which would be at the peak of the HP curve towards redline. Reducing restrictions should show gains in the upper rpms. The engine is an air pump. Exhaust restrictions lead to dimished turbo spool, which then robs lower end power and torque. Removing exhaust restrictions should result in faster spool and more power earlier.
I try not to argue too much on the forums anymore, I learned my lesson
Everyone will have their opinions on parts and they are entitled to them. As far as picking up 2mph on a trap, it could be tire pressure, track conditions, tail winds, better fuel, cooler air and maybe a dozen other reasons, but again if you are happy with your purchase then the only person that needs to care is you.
Everyone will have their opinions on parts and they are entitled to them. As far as picking up 2mph on a trap, it could be tire pressure, track conditions, tail winds, better fuel, cooler air and maybe a dozen other reasons, but again if you are happy with your purchase then the only person that needs to care is you.Last edited by Pb Pedis; Jun 15, 2022 at 06:23 PM.
