Exhaust installed threw a check engine light..
I’m pretty sure it’s not the GMG setup for our cars.. if now after the install I receive the triangle dash light along with check engine. Any insight on what can trigger this? Thank you for any input.
https://shop.gmgracing.com/collectio...exhaust-system
Did you scan?
Simple OBD2 bluetooth and Torque Lite app might do the trick. https://www.veepeak.com/product/obdcheck-vp11/
The catalytic efficiency monitoring is super tight on these cars and will flag anything coming out the exhaust a little rich.
Charles7970 (04-04-2021)
Did you scan?
![](https://cimg8.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/83db79c4_4e60_4eee_98e7_6dbad424bc48_881d935e23e565b7f99398e0b6937663ad7c3357.jpeg)
![](https://cimg9.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/1d0add2a_3d1a_4a2e_98e3_f00682ace9a9_b999568f91be65006f547ce3fe88f7462fcb0b4e.jpeg)
I’m at least able to clear codes with it. It seems lol but it returns on start up
that could be a vacuum leak...check your gas filler lid and maybe check the install on the exhaust
Try this site:
https://www.porscheirvine.com/servic...uble-codes.htm
Try this site:
Try this site:
Try this site:
I didn't have any problem with my new GMG exhaust system on my new TTS. Yes, they are good people & will take care of you.
Tumbleweed (04-04-2021)
Received 2,672 Likes
Charles7970 (04-05-2021)
Google is you friend here. DTC P048C is explained at this link: https://www.obd-codes.com/p048c
Issue resolved. I’m just an idiot 😂 exhaust valves were installed wrong 🤦🏻♂️
The following 4 users liked this post by Charles7970:
Charles7970 (04-07-2021)
The following 3 users liked this post by Charles7970:
