Thx Peter. I had it similarly before, but recently bought the MagCode for a somewhat cleaner install.
The magcode (male) has a quick connect adapter for the CTEK charger; the magcode female can simply be crimped on in lieu of the quick connect at the end of your hardwire.
Very cool and clean! Would you have a reverse side shot of the shroud?
Next week Tue I will have the AL Priority laser installed; I want to see if I can move this connector to the outside, next to the adaptive cruise control 'eye'.
What a clean solution! Thanks, once the newness wears off a bit and I won't mind so much drilling the hole, I will look into this.
In case you do, get this one... and use the 28mm hole drill.
Also, Suncoast has new covers available for approx. $128 or so - I bought one, just in case
Pretty straight forward swap. In total it took maybe 1.5 hours with fiddling, figuring and picture taking. Exhaust swaps are much easier with only 18kms on the odometer....
Soul Sport Cats are a perfect fit! Not always the case with aftermarket bits.
Quick video with ham-fisted editing of some garage blips, nothing too inspiring at this point:
Thanks! Some mfrs advertise as much as 20-25HP with just 200 cell sport cats while other mfrs remain silent on that point. I'm pleased with the turbo sound enhancements, any +HP would be a bonus.
