Battery tracker
Battery tracker
Any one using a battery tracker like the Antigravity AG-BTR-1? My car may need to sit a bit this summer without electricity and thinking this will let me keep an eye on parasitic drain?
I have fitted the C-Tek comfort eyelet and it pokes out through the scuttle by the windscreen wipers so a quick glance is all it takes to see if it's still all good. Worth a look if you have a CTek charger anyway
The following 3 users liked this post by chris956:
Premium Sponsor
We also just came out with a NEW Battery Tracker that offers the ability to check 4 vehicle at one time and has several other new features. Like downloadable data, 72 days of history, tracking of Voltage but also Temp, State of Charge, and quite a few other things... cranking Test and Alternator test.
You can actually search on Rennlist and bit and find what others say... the opinion are always very positive about the Trackers. Its quite useful, if your the type of person who like that type of stuff and ease of tracking your battery. I can also work as a type of multi meter since you have live voltage on the App over the course of a 5 minute span and are testing the effects of adding an accessory or the voltage drop when your interior lighting is on and other data like that.
Here's the link to the new one... and the old one is also still available. https://antigravitybatteries.com/pro...tooth-tracker/
As the previous poster Chris suggested, you should hook it up with the CTEK Comfort Connect Extension Cable (56-304) and you can use the Comfort Connect M6 Eyelet with fuse and indicator (56-629) to hardwire directly to the battery terminals. Very simple DIY and clean.
Hey thanks. So if I have two cars sounds like I want to use this newer version?
I just ordered the old one so maybe I'll return it and double down?
Two discrete use cases:
1. On GT3 the car may be sitting in an un-powered garage for weeks at a time. Understand I cannot do it fully remotely, but at least i could swing by the storage location and give it a check for piece of mind (or pull it and charge it if needed). Hopefully with some data I can get piece of mind around how long I can ignore the car.
2. On a Cayenne it would be more piece of mind that 5 days at an airport in 0 degree weather was not putting me at risk. Probably not necessary but .... i kind of like data and gadgets.
I thought about the CTEK (its what I am using) but my issue with that is its not going to give me enough data to know if its draining and when and why.
The drain is so big that I would suggest simply purchasing a CTEK (56-926) charger for $130 on Amazon and calling it a day.
On my incoming daily I really don't want to be plugging it in - and I travel a fair bit so its not unusual for it to sit for a week + at a stretch.
I could go buy a VW GTI and a Ford Edge and solve all my problems.
Premium Sponsor
Amazon.com: CTEK 56-926 LITHIUM US | Fully Automatic Lithium Ion Phosphate LiFePO4 Battery Charger | 5.0Ah - 60Ah | Maintenance Charging up to 120Ah : Automotive
Orca explain you might be talking about the Cars drains... anyway just wanted to point out our product does draw down a battery.
Premium Sponsor
Also your idea is correct... meaning a great use for the Tracker is to understand exactly how long your cars can sit before you need to get a charge on them. You get to see it graphically, and go day by day and learn that your car takes 2 weeks or 3 months to loose it energy. I do that exact thing, I have 9 vehicles (Cars, Motorcycles, UTV) and I know my 66 Mustang can sit for 6 months without needing a charge but SUV can only sit about 3 weeks. I learned that from just reviweing the discharge on the history graph of the Battery Tracker for the vehicles when I didn't drive them for a while. Also note you can see the charging profiles in your cars as you are driving and even use the History Graph to see if your Car was ever driven when you were away...or even if Valet drove it and how long sincde the voltage changes and it shows when you turn the car on or off and when you drive. You can also track your drives by this if you ever need to. THe history graph is super useful once you understand how much data it shows.
sold!
Premium Sponsor
Premium Sponsor
