Active Matrix LED comes to the US!!!
Well... sorta. They are here but not via pcna. I found some people in the forums who helped me activate the lights on my car. I paid extra for the active matrix hoping that someone would be able to activate them and I'm glad they can on my 2023 992.
The following 6 users liked this post by dogshyne:
911TurboRules (05-01-2023),
Diablo Dude (04-25-2023),
JAM2 (04-25-2023),
mthreat (04-26-2023),
nerdtalker (04-25-2023),
and 1 others liked this post.
![](https://rennlist.com/forums/images/buttons/collapse_tcat.gif)
Popular Reply
06-26-2023, 10:49 AM
For those who want to activate own Matrix yourself: below is the combinations code that work:
USA Matrix Code:8JU+8G4+AV2+B34+8K5 --CHANGE TO--EU MATRIX CODE:8JU+8G4+AV1+B01+8K8--Access to change this value is on Maintenance of vehicle data/F7
autocode these modules: BCM1,BCM2, KOMBI, ZFAS, AIRBAG, CONBOX, LED HEADLIGHT LEFT AND RIGHT, LCM_L/R
PCM.
The automatic coding turn HOMELINK frequency into EU, and Dashboard Languange to German, solution:
For homelink fix on BCM1 manual coding Without |Rule -- Garage-Door-opener-Coding-Values: Change back from 0x21000 to 0x25000 then Write.
To Change language and metric back to US English: in Vehicle Data-Change B01 back to B34, Then auto code: Kombi Instrument only. Done. Cycle ignition off, reconnect Piwis, Delete all errors code.
Final step: Revert the vehicle data back to their original value and save, but at this last step DO NOT autocode. i repeat DO NOT AUTOCODE.
PCM.
I'd also be interested if you can share. I have all the hardware on my car (PDLS+ and the traffic/signage camera), PIWIS and other scan tools too, but haven't found what exactly to code to enable it yet.
abiazis (02-18-2024)
do you have the active matrix now? there is a distinct difference between auto highbeam and the variable higher light output with shading around cars in front of you that result from reprogramming your lights. they are pretty amazing driving at night on a dark road that isn't so dark anymore...
I forgot to add, the pattern and start up animation change as well. I'll get some video of that and photos of the pattern and post here as well.
I sent out some pm's but pls pm me if you are curious as its easier to reply. ha.
thanks!
thanks!
The following 2 users liked this post by dogshyne:
cosmos (04-25-2023),
Diablo Dude (05-21-2024)
you have to have ordered the Active Matrix LED lights when you got the car.. the $4K option. If you don't have those I am not sure if you can retrofit beyond that.. but I heard a rumour that you might be able to once you swap some equipment.
Why so secretive? Ask the peeps that activated them for you if you can post their info on here. RL'ers want to know.
The following 5 users liked this post by ExMB:
Alan C. (04-26-2023),
Captain P (06-22-2023),
daveo4porsche (04-25-2023),
Rxpert (04-27-2023),
Yojeffo (04-25-2023)
I would however be very very interested in existing vehicles with Matrix Headlights can be activated in north america - if it can I have 3 vehicles for which I'd want it done…
richardbf (06-09-2023)
I filmed the startup animation the lights now give as well as the pattern once they are on which is different from what they originally were. see attached:
