992 GT3 and GT2RS Forum 2019-Current
Engine control error Driving permitted / PSM failure
Old 04-07-2022, 04:06 PM
nerdtalker
nerdtalker's Avatar
To close the loop on this one, dealer cleared the codes and OKed me for a track day the next day. No codes have returned, but also no root cause found. I'm at a few hundred miles additional since the issue.
NO WARRANTY CLAIM SUBMITTED USING THE PIWIS TESTER CREATED AND SUBMITTED VEHICLE ANALYSIS LOG, FAULT CODE P010600 implausible, Intake manifold pressure sensor STORED FAULT WAS Signal A ONE TIME OCCURRENCE AND IS NOT A PRESENT FAULT. CLEARED FAULTS AND TEST DROVE, PERFORMED VISUAL CHECK ON THE INTAKE SYSTEM CHECKING FOR LEAKS NONE FOUND, no problem found, at this time the GT3 is running normal, fault has not returned, for the time being nothing else we can do. VERIFIED VEHICLE OPERATES CORRECTLY WITHOUT FAULT RETURN OR FAILURE
Mercuriell (04-09-2022)
Old 12-04-2023, 02:03 PM
mkaplan
mkaplan's Avatar
My 2023 GT3 992 Touring has the same problem. Took it to the dealer and they put in a new fuel pump. That didnt correct the problem. It only comes on at idle. After you drive a few miles it goes off. Dealer said Porsche is aware and it’s a software problem. Porsche is supposedly working on updating software but to date nothing has been done.
Old 12-04-2023, 10:16 PM
nullspace
nullspace's Avatar
This is exactly why my car went in this morning, and I got the same diagnosis. Bad fuel pump (waiting for parts) and future software update. They said they're seeing this on a lot of 992 GT3s, so I'm not too worried. If it's common it will get fixed.
sparetireless (12-05-2023)
Quick Reply: Engine control error Driving permitted / PSM failure
