I alredy broke the two plastic splitters on the front wheels used to vent the brakes
#121
I found the diagram in this link: https://www.porscheatlantaperimeterparts.com
Suspension Control Arm Cover - 9GT 615 170c - Right.RWD. W/GT3. Air guide.
Suspension Control Arm Cover - 9GT 615 169c - Left.RWD. W/GT3. Air guide.
One hint for installing - there are three T30 fasteners that hold each of these on and the Right side is easiest to access the front bolt with the steering turned all the way to the right, the rear easiest with the steering turned all the way to the left and the center one is on the bottom and steering makes little difference. Left side would be reversed.
Also, I removed wheel - may be able to replace while the wheel still mounted, but I appreciated the extra visibility and access without it. If you have a lift, probably makes wheel removal less helpful.
