Help identifying a broken brake part
Hi
I was replacing brake pads and snapped one of the snap-in connectors for the part in the pic. Does anyone know what part this is? (see picture attached below). I've re-attached it and duct-taped it down so it seems OK for now - but what does this part do and should I get it replaced ASAP?
(right rear brakes pictured)
Thanks.
Thanks.
Its the connector to the brake wear sensor. If you are not getting error code, I don't think there is a need to get a new one.
Agreed as to the part. That area can can very hot under heavy braking. If you are not going to replace, remove the duck tape and replace with heat resistant tape.
Is that not the wheel speed sensor?
It's looks to far away from the caliper.
Received 3,879 Likes
<rant> This is exactly why I loathe buying used high-end cars worked on by the owner - and never do any more. You find these little jewels like this, where broken things are taped up, incorrect fasteners are used, kludges all around. I prefer to buy a pre-owned car where the owner never touched it and took it to the dealer, where they at least repair to an OEM standard. <rant off>
I can see all those wires becoming quite crispy over the years because of the excessive heat.
It looks like a speed sensor.
Is there a place to get more workshop manuals for Porsche? Looks like a really helpful resource.
Thanks!
I have 40+ years working on both cars and airplanes. I will take my solutions over that of the dealer community offers any day, especially when my life depends upon it on the track.
I just don't know if we can trust anyone else!
Back to topic, I agree the sensor should be replaced. It provides input to the ABS and stability control system. You don't want to have this fail and give you a nasty surprise at the worst possible moment.
