Anyone ever get a P1433 error?
This is the error:
P1433 Secondary Air Injection (AIR) Pump Relay -J299 Open circuit implausible signal
Car drives fine.
I read it could be a faulty AIR Pump Relay, AIR Pump Relay harness is open or shorted, or AIR Pump Relay circuit poor electrical connection.
Is the relay or air pump easily accessible and where is it?
Car drives fine.
This is the error:
Car drives fine.
Car drives fine.
Nope. I cleared it to see if it would come back and it has not. I'm wondering if I got water somewhere when I cleaned the engine top and underside. Just passed state inspection Friday.
i know what caused the error code on mine. It was due to a loose exhaust vacuum on the rear passenger side. Took me 2 mins to reconnect it to the exhaust valve.
i have read a few discussions about this and it seems to be a pretty common issue on 991.1.
The exhaust vacuum line was obviously disconnected when I checked. so what I did was I jacked the car up in the air and reconnected the line to the valve (2 mins job), then cleared the code. It has been error free for the last 1k miles.
If it's not a loose vacuum line then your solenoid is probably the culprit which would cost a bit more time and money to fix.
