991 PDK clutch SLIPPING/ Hesitation !!! 0-60 !!!
Hi again
Really hope someone know How a Porche 991 2012. 3,4 . Must drive !!
Car has drive 45.000 km now .
NO chrono , NO sport plus
Just standard and with standard sport button
I had for 4 Months now ... and this is The worsest Car i have ever driven . I had Cayenne and panamera and boxster. . But this car is absolute terrible .
Problem :
When i drive away from street light . 0-100 kmh .
It takes 6.2 seconds and Porsche days it should do it in 4,8 second !!!
This problem is worsest When car has been driving 30 minuts and 100 degree Oil
When i start it feels Like clutch slipping , for The first
1,5 -2 second it feels Like you drive an old Audi 2,0 multitronic
Feels No power at all .. But When car hit 4500 it feels ALL power again,
And car drive Perfect as long as you keep it
Over 4500 rpm !!!
i had a small Porsche dealer in Denmark look af it 2 times .
First Time they reset it .
It did not help
Second time they had for 2 days Ground reset everything in car / PDK
They tell me and changed gear box Oil
That Said car Was OK now
The car did feel better and i Also See it changed little better gear
But STILL (special When warm ) The car When starts from 0 it slipping Like an old Audi multitronic
Now i booked Time with one of the largest Porsche dealers in germany to See If it is an problem
If a 991 has to drive Like this i must really Warning everyone from
Buying this terrible car ... worsest car i had ever had ...
PS , another Strange Thing is If i drive on The street with 10-12 kmh and i pump gas pedal i am able to push rpm up to 4000-4500 , without car Moving more than 12 kmh ,,,, feels just Like PDK cut off and do now work !!!!
My old panamera The PDK Worked Perfect , feel Like a clutch to work
I try upload a video
Problem :
Over 4500 rpm !!!
It did not help
The video i uploaded takes car 6.2 seconds .
And somerime The slipping from start is even worse than What you See on video
Also If you want to make wheel spin from start and take of esp and hit
Sport Burton , The car Can not make wheel spin !! Fells Like No torque at all up to 4000 rpm
Like you See on video
But over 4500 drives Perfect and acceleration to 280 No problem ..
Received 1,562 Likes
Your videos only tell half the story: the feel of how the car accelerates, or not, is missing.
To my eyes, it looks like the engine is hesitating and/or stumbling, not that the PDK is slipping.
We had a very similar problem with our 981 which turned out to be clogged/varnished injectors.
I would have the Tech connect the PWIS laptop in logging mode and then reproduce the problem while logging.
Rocky Mountain High
It's not uncommon to feel a slight hesitation when starting from a standstill as the PDK clutches engage. However, what you describe sounds worse than simple clutch engagement.
