GT Silver 991.2 Project
#46
Basic Sponsor
Has thrown a CEL twice now over a few thousand miles, but both instances went away within a few miles. Also running the Fabspeed spacers.
The video was recorded when the car had stock software, so any backfire in the video was on stock calibration.
#47
Sound is great, but too much for daily driving. Luckily can press the exhaust button to close the valves and cruise comfortably around town!
Does the smell bother you without the cats?
#48
Basic Sponsor
I think I am going to be ordering a set of high flow cats for testing purposes soon.
#52
Sprchng, thanks for posting up you car.
I just got a GTS...had a 2012 GTS with aero kit, LWB, Roll Bar, GT3 brakes and other track mods.... I use to track a lot from 2005-2015.
I have searching for track wheels/tires and need to add front lower control arms as I always do for proper camber for the track tires.
What is the offset of your wheels? I'm not going to 21"...I rather go to 19" but some say 19" will not fit with Rear Wheel Steering (RWS) which is on my GTS.
I am going to call Forgeline and HRE and see if 19's fit...I just want to get the proper offset. Thanks
#53
Hello! I ordered the same Recaro Sportster CS Seat Inc Side Airbag. How did you connect heating and airbag plugs? What kind of seat base and slider did you use?
#54
Basic Sponsor
Depending on the width you are looking for, I would recommend something close to the following
19x8.5 et50 front
19x11 et35 rear
19x9 et42 front
19x12 et 54 rear
I don't know what the Recaro airbag plugs look like, or if they will be compatible with the factory Porsche wiring. My Sportsters do not have side airbags, so I had to bypass them.
#55
The heating plugs do not connect to the factory plugs. You will need to run a new wiring harness (relayed / fused) to the battery and switched power.
And what about seat base and sliders? Can you recommend one?
#56
Basic Sponsor
![Talking](https://rennlist.com/forums/images/icons/icon10.gif)
[QUOTE=Sprchng;14486984]Here's a few more from the above photo shoots, enjoy!
Everything looks great. Any thoughts about upgrading the license plate to be road legal? :-)
