PearlAuto + NavTV?
Old Apr 30, 2017 | 05:36 PM
DerekS's Avatar
DerekS
Default PearlAuto + NavTV?
I wonder if it's possible to use PearlAuto's camera with the NavTV interface?
The iPhone dependency makes Pearl a no-go for me - I'm not going to staple my phone to the dash. Plus the issues with the ODB port.
I really want the seamless integrated experience of NavTV but without the hassle of running a wire and drilling.
Old Apr 30, 2017 | 05:58 PM
Penn4S's Avatar
Penn4S
Understand if it doesn't work for you. But the ease of a vent holder for the IPhone and the flat cord extensions for the OBD port make install and use a breeze. For me spending the $$$ on an integrated nav camera that I could spend other places on the car don't work.
But to each his own.
Old May 1, 2017 | 01:58 PM
PTGFAR's Avatar
PTGFAR
The NavTV camera connects to the module by RCA connector. You would have to find out if there is a video output from the PearlAuto OBD module that you can tap into and run a wire to the NavTV module. You would also have to provide power to the PearlAuto module since I assume you don't want to plug it into the car's OBD port. I don't know what other difficulties you would run into.
I didn't want to drill my bumper too. In the end, I decided that it was the best way to do it. It's easy to do and not a big deal.
Old May 2, 2017 | 09:57 PM
DerekS's Avatar
DerekS
I'm actually fine drilling it, I do worry about running the wire though.
Did you have any problems? Did you go with CAM6 like Plenum?
