Rear head restraints
Hi everyone,
New to the forum, Just got myself a 2013 C2S, have 7 year old twins. I had booster seats in my previous car but they won't fit in the 911 so I use the bubble bum boosters but noticed that the kids heads were at a height beyond the upper limit of the car seat back. Am considering getting maxi cosi rodifix for them but before doing that, has anyone tried to make rear head restraints for the rear seats? Might be able to make a board with a cushion or something like that and install it behind the seats. Any thoughts?
Alex
Alex
Received 5,388 Likes
Alex, you do realize the 991 has an automatic head restraint rollover protection system? I'm not sure what you are considering is necessary.
See pictures here:
https://rennlist.com/forums/991/9326...ded-today.html
The OP's twins may just be tall enough that they don't even require a booster seat. In CA, I think the cut-off is under age 8.......so they may be close.
Hi Hurricane:
See pictures here:
See pictures here:
I thought you were talking about a head restraint system. You know, something that would prevent head from snapping back in the event of an accident (like the front seats are designed to do). I was sincerely curious if there was some other feature that I wasn't aware of.
The OP has a fair concern, one that I think about as my kids grow older, too. There are no head restraints in the rear seats of the 911, unfortunately. And this is a problem for adults as well as larger children. (I do carry small adults in the back seat from time to time.)
And it is not available on the coupe.
I'm not trying to start an argument - I would love it if the rollover protection was designed to provide rear restraint protection also, particularly in rear end collisions. I just am not finding anything that would suggest that. Like putting in a roll bar, sure there might be some structural protection to the passenger space but that isn't the same thing as a seat with proper seat belts and head restraints.
If the belts fits your twins right without the booster then go without it. The point of the booster is to make the belts align on their hips and shoulders correctly but it is just as important their head be below the back of the seat back for whiplash. If the booster puts them above the seat back when the belts fit right then this is actually making them LESS safe.
If the belts DON'T fit right without the booster (I would be surprised if this is the case from my own experience) then get this:
I have a 43lb 6 year old. Fits in the rear bucket PERFECTLY with no booster. With booster she's too high. CT law is 6 years old AND 60lbs. Mine is not 60lbs but I would rather her be safe and explain/show the officer she is better off without the booster and/or pay the fine if it comes to that. Every kid and car is shaped different. The law cannot account for every combination.
https://www.amazon.com/dp/B004LE8ZLW
My 7 and 10 year old are short and while I fit my son (7) in a booster last fall, I more recently had a look at that picture to see where his head is at. In the picture, his head would rest against the seat back and my 4'2" daughter would also rest against the seat back. I'll need some sort of booster with a seat car as they grow older. In 2 years my daughter can move to a front seat, but my then taller boy will need some sort of neck support.
I guess I was more concerned about leg room and didn't consider the neck issue.
If the product you referenced works the way I think it does (3 snaps along the top line to change the direction of the shoulder strap), I think it would be dangerous in an accident. The shoulder strap would immediately come under tension and straighten out, opening the 3 top snaps and crossing the child at the neck - which would be disastrous in an accident.
Also: This product has been crash tested in accordance with Federal Motor Vehicle Safety Standards
Thanks for the replies everyone. The issue here as many pointed out is the whiplash problem if you're rear ended. I have a coupe so I don't have the roll over thing anyway.
Jenner, thanks for the link, I'll try that and see how it works but the problem will come back as they grow taller.
Going back to my question, has anyone thought about a board of some sort with a cushion or a head rest from another car that could be installed behind the rear seat? I would think it should be possible.
This picture is from a VW van in which the guy installed these headrests in the rear but obviously in our 911's, it should be done much nicer with smaller headrests that goes well with the interior.
