Ceramic Paint Coating -
Originally Posted by Key Left
I think that you are missing a point.
Ceramic coatings fully bond with the clear coat paint. What does that mean? If you sustain any dent or scratch , in order to repair you must sand the ceramic coating off before any repair can be performed , unlike wax which can be wiped right off. Are we comfortable with sanding down our paint , and how big an area and how far?
Not sure what this sanding part is about. ANY repaint requires sanding as prep.
There is soooooo much confusion regarding these coatings and paint protraction film ((PPF).
Received 5,388 Likes
Originally Posted by spicygal
LexVan - Just curious - why are you re-applying every 2 years? I thought Opti-Coat had a 5 year warranty?
They are not permanent coatings. Can be removed safely. They use some sort of alcohol solution to wipe off.
Gotcha - thanks. I understand that with Ceramic Pro, you have to do a yearly inspection which could require reapplication. I'm still trying to figure all of that out. I've read and read and read and am just trying to educate myself the best I can. I appreciate yours and others feedback and insight.
Speaking to someone at Suncoast, he mentioned that the Xpel clear bras may yellow after 2 years and it needs to be redone? True? I have an agate grey, would it noticeable?
My Miami Blue car was very difficult to polish for some reason, only the Porsche Hard Wax worked and the 3M polish i usually use on all my cars was tough to get on and off. The car had started getting significant swirl marks within a couple of months. I had it prepped and ceramic coated which made a huge difference in the gloss and shine. I stll polish it because of our very dusty climate, but the polish is very easy to get on and off now and keeps the surface slippery so that dust flies off and doesn't stick.
