Laguna Seca 991 C2S 90db limit tips
Old 02-17-2017, 03:03 PM
R_Rated
R_Rated's Avatar
Originally Posted by kayjh
Its hard to know how far the db meter is away from the car's tailpipe, but the standard measuring test is the db reading at 75', not right beside the tailpipe (as far as I know).
That is true. In that video, only look at the sound differences and the reduction of sound level when outside and the mic with is a few feet.
Old 02-17-2017, 03:49 PM
Archimedes
Archimedes's Avatar
Received 3,878 Likes on 1,903 Posts
This thread is the first time I've heard of anyone passing sound at Laguna on a 90db day with PSE on any of the current model Porsches, 991/981/Spyder/Any GT car. That's my favorite track but I've avoided taking my car there due to the sound issue. May have to take my chances at a day there.
Old 02-17-2017, 03:54 PM
Archimedes
Archimedes's Avatar
Originally Posted by bossboy302
Actually, while Monterey County measures and enforces the sound levels, and it does go back a long time, it is pressure from local residents, mostly in Tehama, that continue to oppose higher sound limits resulting in fewer and fewer open sound days, or even 103db days. Come to Sonoma instead.
It's a lot more than Tehama. Pasadera, the area around LS golf ranch, the homes across 68. I passed on a house last year across 68 due to the proximity to the track and the noise. The opposition is not small and it's not simply a 'you moved in next to a race track' issue. Laguna is a holy place to me, but the sound studies done at construction were arguably flawed and the surrounding land owners were arguably damaged. What we have now is a reasonable compromise. And it will very possibly be a moot point and all come to an end when the lease runs out in about 10 years.
Old 02-17-2017, 05:43 PM
Needsdecaf
Needsdecaf's Avatar
Received 2,620 Likes on 1,628 Posts
Make sure the valves are closed and pull the line running to the valve actuator. Presto, valves locked in closed position.
Old 02-18-2017, 12:53 PM
JustBud
JustBud's Avatar
Originally Posted by Archimedes
.......... And it will very possibly be a moot point and all come to an end when the lease runs out in about 10 years.
This would be horrible. Still bummed by losing RIR down here. To lose Laguna Seca would be tragic.
Old 02-21-2017, 12:52 AM
alz
alz's Avatar
Originally Posted by Leecw
if for some reason to get flagged for sound, it's not like its 1 and done, go back out and don't accelerate as hard until you're past the sound shack
Originally Posted by NA430GTS
I run my 2015 991 GTS with PSE on full throttle around turn 5 on 90db limit days w no sound penalty. You should be ok.
Sorry to say it, but you're not going to pass sound there with PSE
Thanks everyone - as always it sounds like it "depends", although it sounds promising that at least some of us have passed the test with PSE on full throttle! I reached out to the organizers and it looks like there are two dings before you are done (although you meant to make some kind of "change" to address the problem before you come back on the track). With all this in mind I intend to go fairly hard this weekend, at least until I get a ding. Will report back on how it goes
Old 02-21-2017, 11:25 AM
tstafford
tstafford's Avatar
Received 1,086 Likes on 622 Posts
Y'all need to move to the South East. We like noise down here!
Old 02-21-2017, 11:33 AM
R_Rated
R_Rated's Avatar
Yes! I don't know of any states or tracks with sould laws for loud cars.
Old 02-21-2017, 11:35 AM
tstafford
tstafford's Avatar
Maybe just a mandated Sunday lunch break for the church going types.
(And the 103 db limit at NCM)
Old 02-21-2017, 11:44 AM
R_Rated
R_Rated's Avatar
That was propaganda started by the non denominationals to be able to get the good seats in the restaurants for brunch from the Baptists and Methodists(aka Christian day drinking, cause brunch without booze is just a sad late breakfast.)
Old 02-21-2017, 12:25 PM
Archimedes
Archimedes's Avatar
But few tracks in the U.S. are situated in one of the most beautiful places on earth with some of the highest property values as well. Laguna is a complicated situation. The noise regs were/are a reasonable compromise to keep the track open.
Old 02-21-2017, 01:07 PM
bossboy302
bossboy302's Avatar
Agree. Own a lot in Tehama, and the quietest vintage racer I have hits 108db, thus aware of the db issues. Situation isn't likely to improve.
Could be worse I guess. Lime Rock Park, CT. has "No racing on Sunday"...ever. Track was built with compromise to local church.
Old 02-21-2017, 01:10 PM
Homeles
Homeles's Avatar
Roebling Road.
Old 02-28-2017, 01:36 AM
alz
alz's Avatar
For future forum search reference- I had no trouble passing sound at Laguna Seca on the weekend. First few runs with Sport off then worked up to Sport Plus (all with PSE off) with no issues. I don't know if PSE on would have tipped me over however I did my final 2 laps with PSE on and didn't get meatballed.
For reference - the sound booth was working as several others did get cited, including a GT3.
Quick Reply: Laguna Seca 991 C2S 90db limit tips
