BG 44k Fuel System Cleaner
My buddy that works as a mechanic at a Porsche dealership gave me a few cans of this stuff. He says they use it all the time on the Porsches they work on. Any opinions on it and do any of you owners use it and how often. Thanks in advance!
I don't know if it helps.
A while back a Porsche tech gave me a bottle of Swepco fuel system cleaner. I tried it in my 996 Turbo but I felt no improvement. I also tried two bottles -- one after the other -- of Techron with no improvement either.
(OTOH, after switching to Chevron gasoline -- from Shell -- my Boxster's engine perked up some. Throttle response was better as was the engine's low end.)
Try the stuff. Use according to directions. If you notice an improvement well, there you go.
If not, consider using a bottle of Techron. The bottle I get treats 20 gallons but I just dump the entire bottle in the fuel tank then fill up the fuel tank with the usual Chevron premium.
The general advice is to if after the 1st bottle you notice an improvement run a 2nd bottle.
Also, it is best to after using Techron to change the oil/filter. Techron can increase oil contamination and these engine's do not need any help -- so to speak -- in that area.
All mechanics use some sort of fuel cleaner because it says it cleans the engine. Does it really work? Nobody can really tell. Even if it works, unless your engine is in horrible condition and you use this stuffs every fill up for a month or two, maybe, you will feel something. Otherwise, no, you are not going to feel your engine running any better. Also, I don't believe BG is Porsche approved. Some dealer just uses them. If you were taking a Camry to a Toyota dealer, they probably throw in some cheap fuel cleaner. Porsche dealers will use more expensive version fuel cleaner and I believe BG is one of the most expensive one out there. I personally tried it many years ago in an Audi. I also happened to did extension work on that car before using BG and sometimes afterwards, didn't see a thing.
I thought you were supposed to use fuel cleaners before oil changes. any cleaning that happens ends up in the oil and you have to switch it out no?
a BMW mechanic also recommended it and told me the right way to do it is before an oil change because after a can if it does its job right the oil will be very black.
I]Refueling
Fuel tank capacity is listed under “Capacities”.
Porsche does not recommend the use of fuel additives
[/I]
You will find that in the owners manual. Having said that, I have used 44k and chevron with tech fuel cleaners (On other vehicles) with some success. Never noticed a difference with the 44k, but the chevron cleaner made the engine response a tad better, and I noticed better mileage. There is a huge mark-up on the 44k and that seems to be what most dealers use, you can get the Chevron at a reasonable price at Advance auto, etc. But what has always bothered me is despite most saying you should use before an oil change and when the fuel tank is empty, dealers add after an oil service and will add even if you have a full tank of fuel???
The current school of thought is that any top tier gasoline has enough cleaning products blended in the fuel that additives are not necessary....
[/I]
Here is the Top Tier web page: http://www.toptiergas.com.
Here is the list of Top Tier vendors, but I generally double-check for the sticker if I end up somewhere that I'm not sure about.
http://www.toptiergas.com/licensedbrands/
I always used chevron w/ techron and never any problems, now I switched to shell nitro+
http://www.shell.us/motorist/shell-f...-gasoline.html
BG44k is widely regarded as one of the top injector cleaners. Granted, most of us (hopefully) strictly use high quality fuels negating ultra frequent use of the stuff, but it certainly cannot hurt every 30k or so..
Don't let a shop hit you hard on this. DYI for 22 bucks a can online.
