Key Memory
Key Memory
I have a new 991.2 and programmed the key memory to save the comfort settings. I was under the impression (obviously mistaken) that it would memorize the last A/C settings. Now every time I get in the car it reverts to the A/C settings I set. There doesn't seem to be a way I the manual to "clear" the key settings. Has anyone else had this problem. I guess I could always use the other key, but there has got to be an easier way.
I'm pretty sure I follow what you're saying. The key does memorize the comfort settings that you most recently set into the memory by using the button on the door, coded to each key separately. The seating position and the AC will automatically revert to the set positions each time the car is started. The memory will not revert to the AC or seating position that you last used in the car (if you changed them while driving) once you leave the car.
For example, if the key memory is set to 72 degrees, the car will automatically revert to that temp each time you start the car, even if you manually changed it to 74 the previous time you drove it.
Do you have Entry and Drive? If you do, you can set car to remember you last settings by going into the MFD and set car to remember your last setting after exiting and locking door.
Yes, mb1. Can be a pain in coastal NC where the weather was down to 20 one day this week and 75 yeaterday. I do have entry and drive, but didn't see the setting. Is it under door locking?
Auto memory will save not only the AC settings - but everything else that can be saved to the key (including things like seat position, steering wheel position, Multifunction Display settings, etc). So if Auto memory is enabled and a service tech changes the seat position, the new position will be saved, losing your old settings. At least the seat (and mirror) positions can be saved not only to the key but also to memory 1 and / or memory 2 so you can get them back.
Similarly, if you have auto memory disabled and you make certain changes and find they revert to the old settings the next time you start the car, it may be that you have to manually save the changes to the key after you make them. I had to reprogram my Multifunction Display at least a half dozen times before I learned this.
I thought I remembered seeing it initially, but the auto memory setting is missing. All I show under locking menu is unlocking (drivers or both), locking (drive away), and comfort entry. Is there something I'm missing? Does the key selection override this option?
I now have two Porsches with Entry and Drive with the system and for the life of me can't figure out how to make it work.
Also, is there a way to have only partial comfort entry on the 911 like on the Cayenne? I want the wheel to raise, but don't want the seat to slide back lest I crush my son.
Latest Update - There is no auto memory setting on my MFD under the locking menu. Although its referenced in the manual. According to the Porsche rep, if I use my key for some time (rather than the dummy) it should remember the last comfort settings. Don't believe it, but giving it a try. Any 991.2 owners with entry and drive have the auto memory option?
My dealer hasn't been able to get an answer form the Porsche rep other than to pickup the car and check the programming. No confirmation that the auto memory should be there. Not sure if I want to go through the hassle since I'm sure they will come back and say everything's correct.
I have a brand new 991.2 with 18 way and no entry and drive. The auto store feature is not present in the MFD menu (I did have it in my Cayman).
My problem is, I can set 1, and set 2, but when I press set "key" the light on the set button stays on and the setting won't save to the key. Every time I get I the car, I have to press and hold 1 or 2.
I have an appointment next week with the dealer. They already checked the car and couldn't find the cause.
I always selected the "autostore" option with my Cayman. As I said, I've already been to the dealer and they believe there's a defect with my car. I'll update this thread when I get my car back next week.
