Cost and process of installing IPD Plenum
Edit, I checked my invoice it was 995 part 250 labor.
Maxr, I recommended you contact Greg @ IPD to help w the install! I paid about $200 for the original install of that IPD plenum but that was because the cab had a recall for anti corrosion and they would already have the bumper off! At least you got the part for half price!
So the final verdict is in. The IPD is installed!
Only took them 4 hours to do it.
Hard to say exactly what the difference is now since I did the BMC filters and AWE exhaust first. But it sounds like a beast!
I was going to do COBB first but got such a great deal on the IPD that I couldn't say no. Thanks Rob!
For those of you who plan on doing the job in the future it does not seem as difficult now that I've talked to the tech. I was almost there myself and chickened out after I pulled the TB. Some shops think the engine has to come out, but that's definitely not the case.
They charged me for 3 hours, which was $513+tax and ate the rest.
Of course the advisor apologized, but the damage to the relationship was done. Other than warranty work that shop will never touch my car again.
Some me people just need to learn customer service skills. It would have been better to check some more resources before calling me to tell me the job was actually going to cost 4 times the amount of the original quote that was guaranteed.
Glad you got her done. There is no doubt that your car is breathing (inhaling & exhaling) more efficiently now with your mods. Is it huge? No, but for the $ the best & really the only option. Will an ecu tune help now too, sure! But you started with the hardware to make that happen. Enjoy!
I just got overwhelmed with the amount of parts that needed to be removed at that point and figured the engine had to come down. Several members confirmed that as well when I posted about it. Even Alex at TAG said the same thing. I guess there's a way and i maybe could have done it, but by that time I was so frustrated that spending 500 dollars didn't seem unreasonable so I put it back together. If I had to do it again, now knowing that its doable without removing the engine, I would try it again, just for the experience. I enjoy working on cars and back in the day I removed and rebuilt a motor and added a supercharger to a Mitsubishi eclipse simply by reading forums just as I do now. However, at this point in my life I make enough money that 500 dollars wouldn't break the bank and there's a better use of my time spending it working.
IPD plenums are consistently priced around $950 for the part regardless of where you go. My install was $250 but this was for both the plenum install and BMC replacement air filters. Used a local source for the install based on recommendations from this site.
Same also on my car about $950 for the plenum and $314 for the install including BMC filters also. Sounds absolutely freakin awesome with my Akrapovic Ti exhaust! Now need a Cobb tune also.
