Musicar Northwest Group Buy — 991 High-End Tweeter Upgrade
#616
DIY?
What would be the downside of buying the Dynaudio MD-102 and using the included bracket to mount it? Then just pop a Burmester grill over it. Seems that it would be $250 cheaper for just a little more work.
#617
You'd have to add capacitors to protect the tweeters, source the speaker connectors, and most of all custom fabricate the tweeter brackets to fit the cavities housing the tweeters (there's no way the Dynaudio brackets would fit). This is not an easy thing to do - tweeters need to be sunken into the brackets with a concave shape to disperse the sound, and the brackets needs to have the right height as well. Otherwise the tweeter dome would sit too high and hit against the Burmester grilles. Nick's Musicar tweeters are well worth the price!
#618
Platinum Sponsor
-Nick
#619
I ordered a set of Nick's tweeters earlier this year. With Nick's kit I got the plastic Burmester grills, except I had the "extended leather" option on my dash. So they sat on the shelf for a few months while i decided what to do.......
After meeting Frank at "Exclusive Option" at Rennsport Reunion Vl, I sent my grills off for the leather covering. I had him cover over the "Burmester" script and the look perfectly matched to my dash. I installed my tweeter upgrade yesterday. While I am still playing around with settings, I definitely like the improvement !
#620
Platinum Sponsor
After meeting Frank at "Exclusive Option" at Rennsport Reunion Vl, I sent my grills off for the leather covering. I had him cover over the "Burmester" script and the look perfectly matched to my dash. I installed my tweeter upgrade yesterday. While I am still playing around with settings, I definitely like the improvement!
#621
Basic Sponsor
Glad the speaker grills met or exceeded your expectations and lovely to see them installed. The dashboard looks complete, wouldn't be the same with the plastic speaker grill unit.
Fine Leather Parts For Porsche
Email:info@exclusiveoption.com
Shop Online: Exclusive Option
#622
They look great, Stevie!
#624
Bought a used 991.1S that had this upgrade so very happy that I found this thread about the history of the group buy. Also good reference for what it must have sounded like before the upgrade! Mine also has the center channel disconnected (previous owner told me that over coffee). I don't know about the subwoofer, I'll have to check.
However, anyone else notice that you need to crank the fader 3 or 4 towards the rear to get that "fully immersed" sound? I am also running bass +3, and treble +1, surround off, linear on.
I'm definitely no audio expert, but in the car I like feeling like I'm standing in the middle of of a concert with the sound coming from all the speakers around me.
I'll probably try to refine the settings as I listen to more music but so far that sounded pretty nice.
#625
I am installing mine soon. I have watched the video many times for the install. It seems that clips can often break in removing trim pieces no matter how careful you are. Has anyone had issues with the vent or ignition surround breaking clips when removing?
#626
No issues at all. Maybe I was a little too gentle trying to pry the parts but you will see for yourself. Just follow the video and be careful of the clips. The wire connectors are a bit skinny, so be careful there, too. They don’t come apart easily.
#628
I ran into no problems with plastic breakage. But I worked on it in a warm garage and the car has not seen a lot of being parked in the sun. The heat and UV exposure can make the plastic more brittle. It’s an easy install and well worth it.
#629
Hey Nick - have not heard form you in a while. Wondering if you have anything new n the pipe for our cars.
#630
