What tire pressures are you guys using?
Old 12-09-2016, 09:59 PM
jlee504
jlee504's Avatar
Default What tire pressures are you guys using?
I just noticed on my 991.2 that it's 35/45? Seems like a big gap and a high? Is anyone keeping them closer to reduce understeer?
And has anyone gotten a flat? Do you have to replace both rears? This was the case on my turbo s.
Old 12-09-2016, 10:15 PM
Al.Fresco
Al.Fresco's Avatar
Check your manual for Comfort/Partial Load tire pressure.
Explained pretty well in this article as well. https://www.edmunds.com/porsche/911/...-pressure.html
Old 12-09-2016, 10:34 PM
FiveRiversGTS
FiveRiversGTS's Avatar
Check here to see who got a flat...
https://rennlist.com/forums/991/9448...th-my-gts.html
Old 12-09-2016, 10:39 PM
STG
STG's Avatar
991.1 C2S
Comfort: Tire pressures 31F/34R cold -- 33/36 hot
Old 12-09-2016, 10:55 PM
jlee504
jlee504's Avatar
Thanks I'll play with them a bit. I came home to fiddle with my tire pressures and I found a freakin nail. Now I have to take the wheel in tomorrow, hopefully they have a new tire.
Old 12-09-2016, 11:24 PM
Need4S
Need4S's Avatar
Most everyone uses comfort setting. Car both rides and handles better.
Old 12-10-2016, 12:07 AM
rkwfxd
rkwfxd's Avatar
I run 30F/65R. Gives it that old school tail happy feel.
JK. Like most others 31/34 but I'm starting to play with it pound by pound for AX.
Old 12-10-2016, 12:24 AM
CSK 911 C4S
CSK 911 C4S's Avatar
vroom
Old 12-10-2016, 01:27 AM
Code
Code's Avatar
JK.
Hell yeah. Let er' rip!
32/34 F/R cold
Old 12-10-2016, 01:50 AM
roadrat
roadrat's Avatar
Thanks for linking that. Very informative article.....except the part where my non-PASM car should not be rolling on 20's
Old 12-10-2016, 02:16 AM
CSK 911 C4S
I'm running +1 above comfort pressures all around.
Old 12-10-2016, 10:55 AM
LexVan
LexVan's Avatar
Received 5,404 Likes on 2,513 Posts
I run higher than most here.
I like 36/40 in the cooler spring (March and April) and fall (October) months and 35/38 in the summer (May-September) months. That was on my PZeros for 37,000 miles (2 sets of rears, one set of fronts). I haven't dialed in the new Michelin PSS yet. I will next driving season.
Old 12-10-2016, 11:33 AM
Homeles
Homeles's Avatar
Been running the PSS for w while now. Running 32/36 and getting even wear across the entire width. Rears being replaced this week with 11K miles.
Old 12-10-2016, 11:38 AM
LexVan
LexVan's Avatar
Ran my first set of PZeros to 15,000 miles. The second set I ran to 21,000 miles. I expect the same from the MPSS.
Old 12-10-2016, 11:48 AM
Homeles
Homeles's Avatar
^^^. Good luck with that
Quick Reply: What tire pressures are you guys using?
