Xpel clear film edges over time?
Try a detailers tool https://www.griotsgarage.com/categor...rs+access.door or a Qtip with Griots Speed Shine.
1. A round pointed toothpick is very effective, if glided using the points around the film edges;
2. A good polymer sealant as Menzerna PL, if firmly applied with a micro cloth along the edges, and then removed almost immediately will do a nice job of mild cleaning and does not leave a white line next to the film edge (you can also use the toothpick tip here after the removal of the excess sealant); and,
3. Xpel markets a "Protection Film Cleaner," which removes contaminants, but it cannot be allowed to dry before being removed with the contaminants with a micro cloth, so you must only do a small area and over lap as you clean with the Xpel Cleaner and micro cloth. Spray the Xpel Cleaner on on micro cloth (not directly on the film and adjoining paint) and apply. Polish out with another micro cloth.
4. Suggestion, if you do use P21S Total Auto Wash, start with a small amount of P21S in a glass container, and dilute it with a small amount of water, up to 1 to 1 with the P21S. I have found that P21S straight can be a bit strong.
Usually, soap and water is all that's needed to clean the edges
Specializing in Porsche/Ferrari since 1995
Why choose GP...WATCH OUR DOCUMENTARY
Follow Moe HERE
GP Fastrak - Ceramic/PPF/Tint in one simple bundle - Click Here for more info
This is why you want to use painter's tape on those edges when detailing your car with polishes and waxes/sealants. A little bit of prep in the begining saves you tons of 'clean-up' time in the end.
) Xpel makes a product I will use....
